headgasket???
yes but it would look wierd. most coolant holes will be blocked. do a compression test. then check the oil to see of theres water in it, (it will look like chocolate milk)
if two joining pistons are low, could be the gasket. if you have no compression in one, then youve got a burned valve, or maybee its stuck open with carbon. if it fails then the head basically has to come off. what is it doing? runnin crazy, ?
it runs cool, but vapor comes out the rad cap. i checked out the plugs and the cyl. 2,3 plugs look diffrent than 1,4 a little darker .no oil . compression test this weekend thanks for the advice.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Could be a bad seal on your rad cap too
