h7 , d2s , d2r , H.I.D
AWD Torque Monster
h7 = halogen bulb used in a projector almost identical to xenon becuase the bulb placement is identical.
d2r= coated xenon capsule (hid) used in a reflector setup like in the new cl
d2s= xenon capsule used in a projector like in bmw and audi
H.I.D.= high intesinty discharge also XENON. d2r and d2s bulbs are used in a H.I.D system along with ballasts. a kit rebases a d2s or d2r bulb into a 9006, h4, h7 connector
1999 CL3.0
okay okay... what i am wondering about is...
can i buy projectors from ebay and use stock halogens
w/o any h.i.d harness/ballast/plugs etc
AWD Torque Monster
not really 9006 projectors suck ass. how bout you buy oem h7 projectors, bulbs, and ill include wiring adapters for $80 or jus the projectors for 50. they will be from a audi, bmw, jag etc. good shit. not cheap aftermarket. and if you ever wanted you could get a h7 hid kit and it would work awesome with the h7 projector. almost identical to a xenon projector setup.
1999 CL3.0
if i baught the oem joint H7 piece (bmw audi jags use)
.... and i wanted the
magnifying - bubble - thingamajig
does that still only cost lost than 100?
AWD Torque Monster
ill sell u just the projectors for $50.
if u want aftermarket h7 bulbs like piaa then pic them up urself.
i can throw in some reg h7 bulbs for $5
and if dont want to spend time trying to adapt your 9006 connector to a h7 i can make you an adapter for $25 or a plug and play adapter for $35
its paid for
an H7 HID upgrade kit will run ya about $300(+-$100) on ebay.
VXCL is offering to sell ya the H7 projectors and an adapter for the current 9006 plug.
If i read it all right.
AWD Torque Monster
Originally posted by dragon084
no ballast or box thing is needed?
if u want a true xenon projector ill let them go for $125 a pair, you would also need xenon bulbs ($60-100 a pair on ebay), ballasts i got for $175 a pair, and you would need a proper wiring harness w/ relays and fuses if you cant make one. ill sell you one but it will cost at least $60
pistacio
09-26-2015 09:45 AM
