H22A 5spd w/LSD
Old Aug 13, 2004 | 09:00 PM
Veritas's Avatar
H22A 5spd w/LSD
i know people have talked about h22's a shitload, but i havent really found one to answer my questions.. so here goes
i've basically made the decision to get this engine from jdm; however, my friend who owns a del sol told me that it's not worth it? i'm pretty much gonna get it still, but i don't understand what he meant. it has good hp and tq. he said that there has to be a lot of interior changes - i know i gotta change my gauges and add a clutch, but other than that, what else is there? he said aside from the engine ($2750), i gotta spend a shitload on other stuff to make my car run correctly or something... any help is appreciated
p.s. what would be the price of installation? i got a quote of 1g, not sure if that's the right price tho
Old Aug 13, 2004 | 09:46 PM
Cocoa's Avatar
2600lb CL
With just the swap, you'll be fine. You can just tune your car for about 100 bucks after some mods to make it run smoothly/maximize their gains. There's no reason as to why you would have to change/upgrade your internals unless you were boosting high boost.
You should call up shops for advice as well. They can teach you a few things.
Old Aug 13, 2004 | 09:47 PM
Veritas's Avatar
that's what i was originally told. if the engine package doesnt come with clutch, do i gotta buy one myself and have it installed as well? thanks for the help cocoa and ill be sure to call up my friend's shpo 2morrow
Old Aug 13, 2004 | 10:02 PM
Cocoa's Avatar
2600lb CL
if it's a full swap, you wont have to buy any extras. It'll come with everything needed for the swap. Motor, tranny, ecu, harness, the works....
Cocoa's Avatar
2600lb CL
extras would be lsd......
Old Aug 13, 2004 | 10:21 PM
Veritas's Avatar
http://www.jazzproparts.com/ProductD...oductCode=H22A
thats the site for the h22a, i'm not sure if its complete
Old Aug 13, 2004 | 10:23 PM
ju5tchi11in's Avatar
roomate has a CL too
he needs to go auto to manual I believe.
Old Aug 13, 2004 | 10:38 PM
Cocoa's Avatar
2600lb CL
yeap, itz a complete swap.
Old Aug 13, 2004 | 10:45 PM
Duece's Avatar
LA`s Top CL
if your thinkin about going for at to 5spd you`ll need all the pedal assemply and you can just drop in any h22 and it should fit right in. and work perefectly fine if you use your obd2 setup,if you were to downgrade to obd1 u must redo your wiring or just make a jumper. I did my swap at SPARKS in baldwin park since it says your located in my area got any questions wanna peep my swap jes lmk.
Old Aug 13, 2004 | 10:58 PM
Veritas's Avatar
yeah, i knew i had to get the clutch. know any good sites that sell cluch sets? oh and btw, wuts obd2 and obd1? i never came across that term on here
Old Aug 13, 2004 | 11:06 PM
lnsyone's Avatar
CL 4 LYFE
obd1 = cars ecu; years: pre 95'
obd2 = cars ecu; years: 96'+
obd2 systems monitors virtually every fuel and emission related components on the vehicle that can affect the emission performance.
Old Aug 13, 2004 | 11:20 PM
Cocoa's Avatar
2600lb CL
lol, thatz what you meant by clutch....was the pedal, lol, okay, my bads. yea you need the pedal assembly as well. Shouldnt cost too much, correct?
Old Aug 13, 2004 | 11:24 PM
Veritas's Avatar
thanks for the info insyone, i guess i got obd2. cocoa, yeh, sorry for the miscommunication, but hopefully i can get it for cheap
Old Aug 13, 2004 | 11:34 PM
lnsyone's Avatar
CL 4 LYFE
for the auto to 5 speed conversion, you'll need:
pedal assembly
master cylinder
shifter
and some other things.
i suggest looking at a junkyard. you may probably find the parts that you need for the 5 speed conversion.
Old Aug 14, 2004 | 07:39 AM
nippon_wa's Avatar
nippon_wa 2.0
stupid newbie question;;
how's the fitment?? perfectly??
cuz.. when i was gonna get sr20det on 240sx... my machanic said that they are dangerous to keep it since they don't fit perfectly..
so.. just wondering..
732xghost
Apr 8, 2008 03:02 PM
Jezek
Feb 2, 2007 11:11 AM
kingmarc01
Feb 17, 2005 08:34 AM
Clean_CL
May 6, 2002 04:24 PM
dcsquirm88
Mar 21, 2002 11:42 PM
