Grinding noise while sorta power braking?
Old Oct 31, 2004 | 07:29 AM
Motohip's Avatar
I'm a llama :(
When I step on the brake and give it a little gas, it starts to make a griding noise. I'm not reving it up high, just around 1.5k or so. Is this normal? I thought it was until the best way to floor it thread popped up and someone said to "power break that sucka."
Old Oct 31, 2004 | 11:16 AM
crazyazn's Avatar
your brakes could just be worn out. there is a worn out brake indicator, where it makes a loud screaching noise either when you brake, or if its worse, do normal driving. if thats the case, you should check all your brakes and see which ones requires new brake pads, the brake pads are cheap ($20 pair), its just the brake disks that are expensive($60 each i believe?) if you need a new one or you can resurface for cheaper price.
Old Oct 31, 2004 | 11:23 AM
wilp99's Avatar
its the brake pads in the back breaking loose bout 1/4 in at a time. kind of like when ur at a stop light and u let off the brake alittle. well atleast my explorer does it.
Old Nov 26, 2004 | 09:54 AM
Motohip's Avatar
I'm a llama :(
But I don't feel like the car is moving at all? Could it be anything else? Yeah, I suck at keeping up with threads :p
Old Nov 26, 2004 | 10:02 AM
sumdumguy's Avatar
a jawful a somethin awful
Go to autozone, pretty sure they are like $30 for rotors. whta does your car look like? I'm in the roc
Old Nov 26, 2004 | 10:11 AM
Motohip's Avatar
I'm a llama :(
Wait, what's the rock? It's a 99, white and stock...and tinted. What does your car look like? And why should I get rotors. It sounds like it's the engine or trasmission.
Old Nov 26, 2004 | 10:21 AM
Motohip's Avatar
I'm a llama :(
I'm in Portland, Oregon. What is the rock!!!!!!111~~~
Old Nov 26, 2004 | 11:19 AM
Slooo97CL's Avatar
ok powerbraking with FWD :ghey:
Old Nov 26, 2004 | 02:33 PM
DrDre1443's Avatar
112K and on 1st tranny!
the noise you hear is normal, my car makes the same noise and I have performance brakes and rotors....it's just the normal noise from the pressure .....just don't do it too much on your car
Old Nov 26, 2004 | 02:39 PM
DrDre1443's Avatar
if you are all worried about a bad tranny filter causing excessive heat in the tranny, why not just get a super monster size tranny cooler and be done with it. now if you want to get a tranny filter so that the coolant lasts longer and cleans better, get the filter!
Ted's Avatar
Ted
I'm guessing roc = rochester?
Old Nov 26, 2004 | 05:52 PM
sumdumguy's Avatar
I tried to post earlier but the site just disapeared.....
I was postin to crazyazn, cuz he was talkin about rotor prices.
as for the roc that's rochester,where I live, and I saw that's where he was.
97 2.2 primrose (god I hate that name) ext. mods= prokits, painted red calipers
and a fart can muffler
Old Nov 27, 2004 | 04:20 PM
Hobo's Avatar
Flap.
well if getting faster times is :gheywave: than you sir are correct
Old Nov 27, 2004 | 04:27 PM
Slooo97CL's Avatar
i cant see powerbraking a forward wheel drive car giving you that much of an egde. doesnt that put extra pressure on like the torque converter or something?
Old Nov 27, 2004 | 04:31 PM
Motohip's Avatar
I'm a llama :(
I don't power brake. I was just using the term to describe the situation in which the noise was made. And powerbraking is bad for the car, but it does give you better 1/4 mile times no matter what wheels are turning.
Old Nov 27, 2004 | 05:35 PM
DrDre1443's Avatar
just think of "power braking" as the cheap man's version of a high-stall torque converter
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
Frathora
Sep 28, 2015 11:29 PM
jliu6789
Sep 8, 2015 08:02 PM
