Green gunk all over again?!
Err I came out of the gym today and noticed this green gunk all over my passenger side rim. My poor racing hart rim was covered with this green gunk. I just wiped it all off. A couple of months ago I replaced my cv boot and the gunk was all gone. Now on the same side the gunk is back? Anyone know what it is? Is it fine to drive with this gunk leaking?
Is it alright to drive around like this for a little white until i get it checked out next week? Just by looking through the rim i see where all the gunk is but i dont know what to call it. Anyone have a picture of the wheel well like behind the rotor?
I saw the gunk to the buttom left behind the rotor to the left side of it.
Definately a booot, dark green is the grease which is in the boot, get that checked out and changed because if not you will have to change that sides entire shatf. If you havent really noticed a big difference in driving then you should be fine, you usually know its on the way out when you have a harder time turning and it sounds like metal rubbing metal. Worse case it locks up and youll need to tow it and change that side shaft. Good Luck
Wtf! I replaced the axle yesterday and today I notice the car wants to turn to the right. Like if i take my hand off the wheel it will go right to the right side. And I almost feel a force pushing it to the right while im driving straiight. And if i hit the gas with no hand on the wheel it will turn to the right. Whatz causing this?
Originally Posted by wilp99
its ok to drive for a while with a broken boot. just dont go in water and dont drive it for like 15 years like that and ull be fine.
SidhuSaaB
May 30, 2020 12:40 AM
