gear ratio's
gear ratio's
is there such a thing as gear ratio's or different tranny gear's to make more low end torgue? if so how much are they and how much for the labor? the reason why i made this is because the 4th gear is so long that if you had the power to finish it you would get to 180 or so ive been in the car when doing 137mph at 5--- rpm's.
Moderator Alumnus
i agree with nomad. H22 gearing is shorter and get you more power, but less top end.
4th gear takes you up to 120 in the 97cl's and like 130 in the 98's. 5th gear from there on, but there is no way that out cars are geared for 180.
how strong can you make the stock 3.0 tranny i need to make it alot stonger because i want to run a 125wet shot direct port what do i need to run this without having to worry to much about throwing the tranny you said something about level 10? level 10 torgue converter please explain what you mean by this
Swaps? $3000 for 50HP? :(
Level 10=Rip Off
Send me the money and I'll do nothing to make your tranny more robust.
My bother fell for the auto upgrade with his prelude and hes still not walking right after the rapeing.
what the hell is there that you can do for th 1st gen 3.0 cl is her no hope in making them fast? that is without having to go through 3 and 5 tranny to get to run low 13's then send it back to the dealer?
Midnight Marauder
Try B&M trick-shift in it. Some say it helps because the fluid is stronger etc.
I don't concern myself with auto-tranny info much so someone else will have to help you.
Originally posted by azn5ucka86
tranny coolers typically run for like 50 bucks or so, maybe cheaper, what mods do you have in your 3.0 already?
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
guyvelella
09-30-2015 11:02 PM
AcuraKidd
09-26-2015 04:10 PM
