gauges
let's see the point is redline 8900 rpm's maybe. accord don't even go that high and don't like the l;ooks of tachs in my car
hahahahahhaahhaahhahahaahah
your engine will blow up so fast if it could go beyond 7000....ahahahaha
unless you get an actual prelude motor, the gauges are pretty useless....unless you just wanna show off that you have a 200hp (3.0) that can hit 8000 RPM
when I read your post, I thought you were going to swap in the h22... I think the guys are just giving you shit for no reason. anyway I think it fits because people get the front clips and switch in everything... that way you know the mileage of the engine too right?
What you would have to do is take apart the Quelude cluster and pullout the actual guages then instal them in your CL cluster housing. I just dont know how you would wire the lighted needles. The cluster sizes should be the same though.
u don't need the lighted needles... just put the needles in unlighted... the CL needles are not lighted so ... you'll be able to see them fine... or you could just wire them to some power source with a resistor... would work the same as indiglos I would assume.
Jul 16, 2017 07:33 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
