front casters and rear toe are out of spec
Hi guys,
I got some questions about suspension (I got stock 97 30cl)
Since my tire won't last more than 20k miles, I went to shop for alignment
Front casters are out of spec, the mechanic said
"These are unadjustable, you need to get ball joints to fix it"
It was $150 per each side.
Right side rear toe was also out of spec, he said
"The lower controll arm is bent, you can't fix it unless replace it"
I think ball joint is too expensive, this there any other solution for my caster?
Please give me some advices for my caster and rear toe
Thanks in advance for your help
p.s. I need to change my tires, and brake pads, where could i get creat deal on these things??
obsessedmotors
Sep 10, 2015 10:49 AM
