Fog lights- How to install new bulbs?
Old Jun 4, 2003 | 01:48 PM
xrunner86x's Avatar
A-CL Totaled Member
Ok my CL has factory style fog lights installed aftermarket by the dealer. How do you change the bulbs on them? It looks like you have to unscrew them at the side but they are rusted so before i go to the trouble thought I'd ask.
Old Jun 4, 2003 | 04:10 PM
CO30CL's Avatar
Yea. I had to replace one of mine recently too and wound up taking the whole fucking thing apart. Kinda tricky clip in there too. Either I was unable to see an easier way of doing it or its a pretty poor design. At least the replacement bulbs aren't too expensive (< $10). Good luck and reply how it went.
Old Jun 4, 2003 | 08:17 PM
uiskibum's Avatar
its paid for
Yeah you have to take the whole unit off the car and get into it from the back. Mine are so rusted that when the time comes or when i get the money i am going to replace my factory ones with a nice set of piaa 1400's
Old Jun 4, 2003 | 08:41 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Right.
You'll need to remove the 3 screws that hold the fog light to the bumper. Then unplug the wiring connector.
Remove the 5 or so screws on the back of the fog light (make sure not to loosen the screws that adjust the angle of projection).
Once you take the back off, you'll see that the bulb is held in place by a thick piece of steel wire with a loop at the end. Push down on the loop, then slide the wire away from the back of the bulb.
Disconnect the plug that connects the bulb to the foglight.
MAKE SURE YOU DON'T TOUCH THE GLASS OF YOUR NEW BULB!!!!
Insert the plug into your new bulb, and reverse the above process.
It's kind of a pain, but easy enough to do!
BoricuaTL
Apr 8, 2016 01:08 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
Greengecko
Sep 16, 2015 08:19 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
