Fog lights
Fog lights
I was wondering if it was possible to fit fog lights into the clear corners of my car (3.0), cuz ive seen a 3.2 CL-S do it, but i duno if my 99 3.0's corners are big enuf...thnx for any info
Stage 1 Audi S5
I dont think any CLS owner has done it. I know they have put them in their "road lamp" housings but not there corner lights. As for doing it to ours, if you could find a small enough fog you probably could do it but fogs get extremely hot and would probably melt your clear corner.
Why don't you find some rectangle ones that look the same size as tha corner lights. Mount them right next to your clear corners. That is what I plan to do but haven't done it yet.
acura-cl.com OG
http://www.piaa.com/displayLamp.php3?inc=2100x.html
i want to get HIDs but they are expensive (rite?)...and like i said b4, I dont like the look of extra housings hanging out front, when and if i get some money I'll probably look into those PIAAs and see if they fit into the turning signal housings...
Originally posted by joeshmoe
I just got my OEM lights from Warren this week. Gonna put them in either tonight after work or sometime this weekend.
My Home Planet
How much were your OEM fog lights the dealer quote me 2 something so i just said forget that
A-CL Post Whore w/N2O
Warner still sells them on eBay. He selling a set right now: http://cgi6.ebay.com/ebaymotors/ws/e...rid=moose68163
I got mine from him about a year ago for $99.00! :P
dumbaznboy: I like your idea. I was looking at a 2nd gen today, and thought your idea was cool.
Unfortunately, I think that even if you were to swap in a higher power harness, the bulbs would melt the lenses.
The harness/bulbs that are currently in the 2nd Gen CL are so weak, that for 2003, they don't even have the road lamps anymore.
I scuffed my Puma
Originally posted by dustbuster4
Why not just install the OEM fog lights? All CLs are prewired for them, and they only take about 90 minutes to install.
acura-cl.com OG
Dust, what do you mean by prewired?? Not having to run a harnes or no need to install a switch? I am curious?
MR O'NEAL
i go with dust... OEM fog lights-- by prewired, he means... i'm pretty sure all you have to do is add the switch in.. (opposite of the seat warmer switches) you just have to hook up the fog lights to the wires and you're good to go
All 1st gen CLs are prewired for the OEM fog light kit. When you buy the kit, you only need to plug the harness from the kit into the harness that's under the hood (at the fire wall), then mount the switch into the appropriate location (just pry up the "dummy" plug, and the connector is right there)! Obviously, there's more involved to mount the lights in the bumper, the the wiring is simple.
There are 2 kits: The '97 kit, and the '98-'99 kit.
Basically, the only difference is where the interior switch is located.
On the '97 models, the switch is located on the passenger side of the shifter (opposite the seat heater buttons--for those who have them), near the cigarette lighter:
On the '98-'99 models, the switch is located near the clock.
Originally posted by dumbaznboy
how do u pry out the dummy plug in the 99 cl?
Just use a small flathead screwdriver to pry out the plate that's to the right of the clock. The switch connector will be right under it.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
