Fog lights
Originally posted by marko
yes, for sure it is. standing at the front of the car, look on the firewall about a third of the way across from the left. you'll see an orange plug with blue tape.
Did you locate it?
If you need any info on getting or installing fog lights, I'd be happy to help!
All 1st Gen CLs are wired for Fog Lights.
The factory harness (plug) should be in the same place.
The switch will be mounted where the "knock-out" plate is on the right side of your clock (it pries out with a small, flathead screwdriver).
The factory fog light kit (that you purchase--get it off of eBay) will come with the switch, 2 wiring harnesses, both foglight housings (and horrible H3 bulbs), hardware, plus wire ties.
Originally posted by SumkidwithaCL
Hey Dustbuster... where is the plug inside the car for the switch?? Also... whats so bad about the H3 bulbs they come with????
The H3 bulbs that come with it are standard hallogen bulbs (that yellowish/white color). I immediately replaced them with HID bulbs.
Anyone wire non-OEM Fogs to the harness? I want to hook my PIAA's up to the stock switch where would the connector be that runs to the switch. BTW I already bought the swtich but couldn't find where i had to run my lights to so i gave up
The factory plug (C355) should have blue tape on it
on a scale of 1-10 with installing fog lamps non-oem being a 5 how difficlut would it be to "custom" wire them to the switch..? Do you have any kind of electrical diagram showing what goes where.? I'm going to run out to the car to have a look BRB in 5mins thanks
First of all, trying to get the factory plug away from the firewall is a job in itself. I say this because you'll need room to work with it. It was a bitch just trying to get the fog light harness plugged into it. I imagine you would need to cut the plug off of the factory harness and solder your PIAA wires to it.
I don't have a wiring diagram for the factory harness (plug). I only have a diagram for the OEM fog lights.
by some chance does C355 plug into the plug to it's right? not the group of three but to the lone plug on the right of that?
Could it be that i Don't have a C355? i've got a 97 3.0 Premium
C355 is not in that cluster of three. which btw was a pain to un-hook with that nut in a tight spot.. i took the cluster out and there's nothing but wires. couldn't see another plug.
Here's a photo of where the fog light harness plugs into the factory harness.
The location of the factory harness is directly below where it's seen in the photo (it's the yellow-looking plug). The fog light plug is connected to the orange/red/white wires that I'm holding.
I hope this helps!
I hope this helps!
Found it but it's got a stupid twist tie thing at the bottom of the car. Tried to cut it off but there's no room to manuouver. Also I have no idea on the polarity of the two orange wires attached to C355. After giving up I dropped my flashlight into the freakin engine... Was scared cause i couldn't reach down to it.. Luckily I reached under my car and managed to pry the stupid thing outta there.. Thanks for the pictures Dustbuster4 but i don't think i can do this. without some help
Hopefully, someone can clarify the wiring polarity for 'ya!
I can not find the fog light prewired wires! Please help=(
Hello, im new to this forum but it has been helping me since i've gotten my- 1998 Black Acura Cl 3.0 stock. But i sure hope that someone could help me find out if my wires are somewheree else for my year or changed colors?? Or a picture would be greatly appreciated, the ones posted earlier on this topic cannot be seen with the message for some reason.
Thank you in advance=)
p.s.- looking for a good "fog" light with green "angel eyes"
your wire should be in the same place under the hood, the only thing that would be different is where the plug is located for the switch. On the 98-99 its beside the clock on the 97 its beside the shifter. You will have a hazzard light switch on one side of the clock and a blank on the other side, you have to pry that blank out with a small flat head screwdriver and the wires should be attached to that blank, just take the blank off and hook the fog light switch to it
Also I have looked at the blank but the blank was perfectly flush to the surrounding plastic, there is no designated place to try and pry it open. The only blank ive opened in my car is the small one next to my automatic shifter. Nothing was inside though, so I'm wondering what thatd be for as well?
ok the 97 has one beside the shifter like you are talking about. Thje plug opn the drivers side is for heated seat switch and the one on the passenger side of the shifter is for fog lights and the wiring is attached to that plug but on 98 and 99 I am almost positive its on the other side of the clock. On one side you have the hazard light switch and on the other side its blank. You should be able to pry that blank out and the wiring should be attached to that blank. I have never wired these up myself so I do not have any pictures but I have a 97 so I couldn't take a picture of the blank for you since mine is different than yours. About the wiring I am sure you know this but the left is the drivers side of the car and I have never looked for the wiring I am just going by what everyone else has said about it being there and have never seen one where the wiring wasn't there so it should be there somewhere. They say its hard to get to the plug so it may be under allot of stuff in there but it should be there somewhere, but pictures will have to come from someone else since I haven't looked for the one under the hood and mine in my console is different than yours
Ya, this afternoon I got bored after not finding the wiring under the hood. But i did manage to pry open the blank beside the clock and the plug for a switch is there, so now all I have to do is find it lol.
Also about the switches beside the shifter, I know what those blanks are for, but there is an even smaller blank RIGHT BEDIDE my shifter, thats the one im talking about.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
