fitting a d2r bulb into a 9006 housing
its paid for
I am thinking of setting up a d2r bulb into the factory housings, I was wondering if anyone has any info on this, pictures, a DIY guide, has a friend that did it, read it somewhere etc. I talked with VXCl and he gave me the asic idea behind it. Thanks again! But I just wanted a little more to help me visualize it.
Thanks guys!
Thanks guys!
The movement has started
You might want to go with bulbs from a Hid conversion kit look around on the net youll be able to find a set...it might be as much as d2r bulbs Im only doing this just incase one day i want to sell the cl i wouldnt have to replace the headlights. Plus i like the oem housing look like the Tl's. Im goin with this setup as soon as VXCL gets some ballasts in.
-S namyaC-
My kit had drop in 9006 bulbs. Same capsule as the D2R, diff base.
http://www.acura-cl.com/forums/showt...hreadid=122906
AWD Torque Monster
your kit completely changed the base of the d2r or d2s bulb. some kits actually leave the d2r/d2s connector. if u could get your hands on those bulbs then you could use any d2s/d2r ballast, but i have a feeling the bulbs would be $120+ a pair. an hr or 2 of your time is worth it not to mention those bulbs are going to be crap n e ways.
AWD Torque Monster
easy. just take the 9006 lock off with the 2 screws and the hole os already there. then fabricate a small piece out of sheet metal to hold the bulb in place and reuse the same screw mounts. simple mod for those with a dremel or similar tool and who like this kind of work.
-S namyaC-
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
AWD Torque Monster
what i meant is that no kit manufacturer has the quality and standards of philips or osram when they re base a d2r/d2s capsule. and very few actually use osram and philips bulbs to begin with. crap maybe kinda harsh, but u get the point.
-S namyaC-
PS: I checked around a few sites, and there is a diff cable I can add if you guys finally talk me into some projectors and I need a standard D2S/D2R connector.
In a 3.0, you'll want to pull the headlights out, cause on the passenger side the ABS motor is too close to the headlight, so it makes working on it a total bitch.
Be VERY CAREFUL when putting the screws back in, if you overtighten them by the slightest bit, you'll strip the threads in the headlight... I did that and had to fill them with epoxy and re-drill them and thread the screws in again. BIG SETBACK!
its paid for
Originally posted by SumAccordGuy94
A large, proper sized washer works wonders. Make allowances on the inside of the washer for the locking "teeth" on the base, and make your 3 holes for the screws... dosent look too bad either.
AWD Torque Monster
pistacio
09-26-2015 09:45 AM
09-17-2015 09:01 PM
