First Gen Trunk
Old Jan 16, 2004 | 05:47 PM
Acura2.3CL's Avatar
First Gen Trunk
My amp was working fine for a while and then the ground got screwed up, then I fixed it, then it happened again, then it was fixed, and now it is going again! I am sick of this shit!! I need a new place to ground to. Where did you all ground your amp? Pics?
Old Jan 16, 2004 | 06:12 PM
Bdog's Avatar
Not Registered
Drilled hole in trunk, cleaned everything off to bare metal, attached ground wire.
Old Jan 16, 2004 | 06:57 PM
wilp99's Avatar
use a bolt, and nut. thats what i did and no more loose grounds
Old Jan 16, 2004 | 07:17 PM
JetBlackAcuraCl's Avatar
Promiscious Boy
lift off the carpeting on the left side towards the back of the trunk....there should a bolt there...thats where i put mine...i think it might be the strut actually
Old Jan 16, 2004 | 11:17 PM
baka_t's Avatar
The movement has started
Any bolt in the trunk thats connected to the chasis will do
Old Jan 17, 2004 | 01:12 PM
Acura2.3CL's Avatar
should i solder the connection, would that help??
Old Jan 17, 2004 | 05:47 PM
baka_t's Avatar
I would use a 8ga crimp on spade connector and tighten the bolt over the spade.
Old Jan 23, 2004 | 05:55 PM
laslo's Avatar
~aka~chester~pingusa~
no no on the solder thing . but make sure its not on the paint . it needs to be bare metal
emailnatec
29
Sep 28, 2018 04:27 PM
baelim
May 10, 2018 09:53 AM
Jul 16, 2017 07:33 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
