F'ING Radio
Old Apr 18, 2004 | 09:25 PM
Sir's Avatar
Sir
CL = Can't Lose.
F'ING Radio
My car's battery died yesterday and I jump started it today. It is running fine now, but I still plan on purchasing the optima red top battery tomorrow.
The problem: The stereo no longer works. It says error or CO something or another. If I try and put a CD in, it doesn't reject it, but it doesn't take it in either. The radio does not work.
Is it a fuse or something...wtf is wrong with it?
Old Apr 18, 2004 | 09:27 PM
DanMan1464's Avatar
Autobot
it isn't locked? i know that if u unplug the battery you have to enter a code
Old Apr 18, 2004 | 09:43 PM
Sir's Avatar
Sir
CL = Can't Lose.
huh? What isn't locked? And it stopped working before the battery was taken out.
Old Apr 18, 2004 | 09:57 PM
DanMan1464's Avatar
Autobot
oh...i thought the deck would be locked...which would most likely reject CD's....my bad
Old Apr 18, 2004 | 10:02 PM
oz.one's Avatar
If the radio is without power for a certain amount of time the safety system kicks in. That happened to me. you have to get the serial number off the bottom of the radio. then caal the dealer and get the codes to punch in. unless you have them in your manual. I didn't.
Old Apr 18, 2004 | 11:31 PM
bmterp's Avatar
take out the ashtray in the dash under the radio. mine has a small sticker with the code on it (5 digits, each digit is from 1 to 6)...enter it with the radio preset buttons
Old Apr 19, 2004 | 11:06 AM
dogfight's Avatar
this topic must have been covered dozens of times at this forum (everybody's had it happen!) and you can get detailed info by doing a search
Old Apr 19, 2004 | 11:16 AM
fusionnv's Avatar
Gimmie my points Biatch!
It the code is different for everybody, in wat it is and where it is. The Dealer that you got the car from or previous owner will be able to get the number. Otherwise you have to bite the bullet to check the sn numbers. Yes we all know it is gay and probably more trouble than it is worth.
Old Apr 19, 2004 | 05:42 PM
Sir's Avatar
Sir
CL = Can't Lose.
Thanks a lot.
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
