Fawk!!!!
Old Mar 11, 2002 | 10:18 AM
acura2.2vtec's Avatar
I use a condom?
Fawk!!!!
I broke both of my rear suspension bolts. So I decided to drill them out....well that didnt work, so I had to cut the shock off and am going to have it towed. Boooo. At least i got the front ones on no problem.
Old Mar 11, 2002 | 10:37 AM
RidinLow's Avatar
Scooby Guru
Yeah, when I broke mine, I cut off the shock with a saw. Then you gotta press the bushing containing the stuck bolt out, then press a new bushing in, then replace everything. And when I say press, I mean press... as in hydraulic press.
Or, as an alternative, when you break the bolt's head off, you can still gently drive to your nearest garage. It won't be a problem for any shop to take care of this problem.
Old Mar 11, 2002 | 10:58 AM
I use a condom?
Daymn a machine press huh? How much did the new bushings cost you? Did you get them from the dealer?
Old Mar 11, 2002 | 11:00 AM
RidinLow's Avatar
Scooby Guru
Yeah, they were about $20 from the Honda dealer.
Old Mar 11, 2002 | 11:15 AM
I use a condom?
did you do this yourself?
Old Mar 11, 2002 | 11:27 AM
RidinLow's Avatar
Scooby Guru
I finished one side, decided it was not worth my time, and limped over to the shop and paid them a little over a hundred bucks to finish the rest. Damn rust.
Old Mar 11, 2002 | 11:40 AM
I use a condom?
heh i hear ya. When you pressed out the bushing was it still on the car or did you have to take everything off? Also did you have to press in the new bushing? Sorry for all the questions.
Old Mar 11, 2002 | 11:43 AM
RidinLow's Avatar
Scooby Guru
It was still on the car... I used a big ass clamp, a chisel, a sledgehammer, a torch, a saw, and some other unorthodox methods to remove the bushing.
It would be 100x easier to get the car on a lift, remove that suspension arm, and put it in a press to remove the bad bushing. But unfortunately, I don't have those things at home.
Old Mar 11, 2002 | 11:55 AM
I use a condom?
So its not just the steel thing in the inside but the whole rubber piece that comes out right?
Old Mar 11, 2002 | 12:00 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Right!
I had to tear out my bushing in order to get the bolt out. I then carefully put it back in place, installed the shock, took it over to Acura, and they pressed a new bushing into place. They use a 10,000 ppsi press!
Old Mar 11, 2002 | 12:07 PM
I use a condom?
Originally posted by dustbuster4
Right!
Damn, so this is something i obviously can't do at home.
Old Mar 11, 2002 | 12:09 PM
I doubt it! The force necessary to press out the old bushing and install the new bushing (done in the same step) is absolutely incredible. Better to do it right through a shop!
Old Mar 11, 2002 | 12:16 PM
RidinLow's Avatar
Scooby Guru
Agreed, I couldn't believe how much clamping force I had to put down to get that 1 bushing out.
Just remember to have the shop put antiseize on the new bolt so nobody will ever have to go thru this again.
Old Mar 11, 2002 | 12:19 PM
"Fawkin' A"! I put antiseize on all of the bolts! Made taking it apart (to install the AGXs) a breeze!
BigPimp
Money & Investing
Sep 30, 2004 10:08 AM
