factory Fog
factory Fog
does any know which parts do I buy at acuracarland for the factory fog? because I am confused with fog light kit and then there are fog assy L and fog assy R also...please help, thanks.
My suggestion is that you check with this dude first: Warner. He works at an Acura dealership in Canada, and I've bought a number of things from him (He's Legit).
He currently does NOT have a set of OEM fog lights on eBay, but if you send him an e-mail, he will beat the price on acuracarland. I got my complete set for $99.00!
The last several sets that he's sold went for around $150.00. Give him a try moose@dccnet.com his name is Warner (tell him Rick Hoover/dustbuster4 sent you).
BTW: What you need to purchase from acuracarland (if you go with them) is FOG LIGHT KIT for $211.34. This has everything you need.
Originally posted by Gshock
Hey Dustbuster
thanks I will give him an email and see what's up. was it hard to install by myself?
Hey Dustbuster
Installation only took about 90 minutes. The hardest/timeliest part was trimming away the front bumper grill, where the lights will mount on the bumper. Otherwise, it's just a matter of following the easy install directions.
Wiring is easy because most of the wire are already pre-installed.
Do a "search" on this board and you will find a ton of instructions. Plus the factory fogs usully come with instructions.
It is about an hour job or 2-3 beers.
Good luck!
Good luck!
Originally posted by Eleven
if i wanted to install the factory fogs, how do i do the wiring? was it hard to do? and how much for the factory fog kit?
I just contacted Warner, he replied to me and said that he doesn't have any to sell.
so got to find other way.....
Your best may be to purchased the FOG LIGHT KIT. This price is about $120 less than the dealer!
You'll need the '98/'99 kit as the '97 switch will NOT fit your '98. Otherwise, everything in the kits are identical.
I want to add a Cd changer to my 98 CL. Do you know where the input jack is in the trunk? Are the Sylvannia super whites any good? Where can I get white dials for my dash?
Thanx!!
Carlos
Thanx!!
Carlos
