Factory Alarm
Turn Signals are good!
Yes, the alarm is under tha passenger seat... as far as the pin diagram.... i'm sure someone on here has one, maybe try searching for it... either that or grab a test light and start hitting buttons. What are your intentions? Shock sensor?? replace the alarm?
Hum........what next??
Yep!
I am adding:
DEI 504D shock sensor
DEI 530T window module
second alarm horn
Anyone have the CL bible (shop manual)?
Please let me know what the pin codes are.
I am adding:
second alarm horn
Stage 1 Audi S5
You can add a window module to the stock alarm? Or are you getting a whole new alarm? If not how is the window thing going to work? Like what will make them go up and down? Oh the stock alarm horn is in the front left fender well in the 2.2 but probably in the right fender of the 3.0 due to the resonator in case you didnt know where it was
the alarm horn is located next to the car horn......dead center just below the hood latch (at least on the 3.0)
i like chicken
yeah and your car wont start with that brain removed. it controls more than the alarm. so be careful. i dont want to tell you what those things cost from the dealer.. $$$$$$$$$$$$ if you get scared i have a 4 channel remote setup you can make your car do just about anything with. it is a brain, 4 channel output to anything, with 2 relays, 2 remote controls, instructions, etc... it is actually a door popper kit, but you can use the channels for other things.
i like chicken
Originally posted by CL-Z
Huh.........it must control the starter kill or something like that.....
yep, i took it out when i dampened the floor and she wouldnt start.
