f23a1 head f22b2 block
Old 11-18-2014, 10:32 AM
K1nGD1cK805eR's Avatar
I have a Frankenstein engine on this cl I just bought,need some ideas and opinions.I bought a jumper harness to run a obd1 ecu but when I started it,it stared idlelling fast and ran like crap..is the obd2 harness a problem,obd2 injectors.Should I swap out the harness or keep the old ecu and add a knock sensor,what would be the best solution?
Old 11-18-2014, 05:13 PM
teh CL's Avatar
Did you buy the CL with the motor already swapped in?
What year is the CL?
Which obd1 ecu are you using?
A little info goes a long way..
97BlackAckCL (11-20-2014)
Oakroadsteve
10-28-2015 10:28 PM
07Acuradude
09-29-2015 03:01 PM
Eggs999bacon
09-24-2015 10:08 AM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: f23a1 head f22b2 block
