f22/f23 ECU question
Old 08-04-2004 | 02:27 PM
ju5tchi11in's Avatar
roomate has a CL too
This is a rumor I heard.
that since this engine is in the accord too it is an ultra low emissions vehicle/engine... so when adding i/h/e onto the engine the ECU will keep the emissions low and counteract the upgraded airflow and exhaustflow.
as a result having those mods will not give an increase in power but may not net any gains or even reduce enginer power.
has anyone dynoed stock f22/23 and then with i/h/e?
Old 08-04-2004 | 03:11 PM
Hobo's Avatar
Flap.
there have been dyno's and people see increases, although headers on the 2.x seem to not do too much compared to the v6's. the main problem is that its a naturally aspirated 4 banger...
Old 08-04-2004 | 03:19 PM
so... point me to the dynos.
Old 08-05-2004 | 11:46 AM
I guess no one knows this one... challenge?
Old 08-06-2004 | 12:03 PM
Old 08-06-2004 | 08:15 PM
ayougo's Avatar
B A N N E D
i personalyhave all three. plus alot more but just the 3 basics on the car i notice a good amount of torqe and hp specialy in the transitions to higher gears like 1st to 2nd pulled and breaks looks, the into third ( normaly tame ) slams you into the seat and 4 th is a mild but distinc pull all the way up to 5 which is a smooth acceleration to 130 or top speed. Thats just with 3 basic bolt ons, with internals done it pulls hard in every gear and a tad in 5th to redline
Old 08-07-2004 | 12:05 AM
I have all 3 too... I just would like some solid evidance... but I guess no one went onto the dyno with just these bolt ons.
Old 08-09-2004 | 06:55 AM
froggystyle14's Avatar
"FROGGYSTYLE"
dude, i have all that and some more and it seems like i should be haviong more power that what i do. after my next paycheck, i will fiond a dyno around knoxville,tn some where and get it tested. further more, i am putting a 95 honda accord ecu on my car with the mugen cip in it so maybe it will do alot more. i will dyno before i put it on. peace
Old 08-09-2004 | 08:47 AM
Hobo's Avatar
Flap.
i found them!
i knew they existed.
http://home.insightbb.com/~niedejb/
Old 08-09-2004 | 08:51 AM
Hobo's Avatar
Flap.
granted his NA dyno's still arent with only ihe, but there are dyno pulls where the cam gears and fuel pump wernt being used.... the pullies are also a common mod, and this clearly shows that there is some gain with IHEP and i dont think that you would argue that this is all from teh pullies, so the ihe have made a difference.
Old 08-09-2004 | 10:53 AM
yeah but the pullies make a lot of difference... good work on the dyno sheets I forgot about those... froggy I'll await your results, I wonder how much the lightened flywheel and clutch do, perhaps your ignition may help out just a tad.
TypeS860
09-03-2021 06:42 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
Skirmich
10-01-2015 12:59 PM
navtool.com
09-25-2015 05:15 PM
Quick Reply: f22/f23 ECU question
