A/f Gauges
Old Nov 27, 2001 | 11:08 PM
KC CL 1785's Avatar
cmng 2 a lawschool near u
A/f Gauges
Hello, recently I have been seeing a lot of people asking about A/F gauges. I understand the point of an A/F gauge, but what is the use of getting an A/F gauge if you can not adjust it anyway? Also, the same goes for oil pressure and oil temp. The reason I am asking is because I have been looking into getting some gauges, thanks for all the help.
Old Nov 27, 2001 | 11:10 PM
CLpower's Avatar
teh Senior Instigator
well, they are used as precaution to warn you when your motor is in trouble
Old Nov 28, 2001 | 06:20 AM
RidinLow's Avatar
Scooby Guru
You can adjust it with an AFC or SFC.
Old Nov 28, 2001 | 09:26 AM
acura2.2vtec's Avatar
I use a condom?
or a VFAC
Old Nov 28, 2001 | 10:01 AM
RidinLow's Avatar
Scooby Guru
What's VFAC?
Old Nov 28, 2001 | 10:16 AM
I use a condom?
It's made by Apex'i and it basically does the same thing as a SFC but it allows you to modify your VTEC engagement point too. I think they sell for about $400.
Old Nov 28, 2001 | 11:21 AM
RidinLow's Avatar
Scooby Guru
Ohh, you mean a VAFC.
J/K, just bustin your chops.
Old Nov 28, 2001 | 12:00 PM
I use a condom?
Boy I autta......back hand your ass. You better give me some respect. I've got the second most miles on my car and I STILL OWN JOO!!!!!!
Old Nov 28, 2001 | 11:23 PM
KC CL 1785's Avatar
ok, let me get this straight, if I buy a/f gauges and oil temp gauges, and I don't have a way to modify A/F. It won't be idiotic to have the gauges? Sorry, for the questions, where I come from everyone who has gauges can modify them, just making sure I wouldn't be a complte idiot for getting them, how much do they cost anyway?
Old Nov 29, 2001 | 06:18 AM
RidinLow's Avatar
Scooby Guru
A/F gauges are cheap, they run about $50. Easy to install, too, you just need to tap a few wires. If you get it & the A/F ratio is fine, then you're good to go... and if it's not, then seeing the incorrect reading everyday should motivate you enough to buy a controller to adjust the mixture.
Old Nov 29, 2001 | 10:45 AM
NOMAD's Avatar
Midnight Marauder
What is an SFC? I've only heard of a VAFC.
What is the cheapest method?
Would a Fuel Pressure Regulator Solve any of the leaning out problems?
Old Nov 29, 2001 | 11:37 AM
CLpower's Avatar
you don't really have a use for them. It'd be kind of pointless to waste your money on them seeing that your car is so close to stock. And also, i highly recommend an EGT gauge over the A/F gauge.
CLpower's Avatar
yes
Old Nov 29, 2001 | 12:52 PM
NOMAD's Avatar
Midnight Marauder
So if I have a A/F and then get the Fuel Pressure regulator won't I need to get a Fuel pressur guage to do the modification that I need to do?
Old Nov 29, 2001 | 01:08 PM
f0de's Avatar
Ham Sandwich
yah you put that under the hood tho.. not on yer dash
Old Nov 29, 2001 | 01:25 PM
NOMAD's Avatar
Midnight Marauder
Ahhh... Thanks
Jul 16, 2017 07:33 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
Billu99tl
Sep 13, 2015 11:30 AM
