even the search takes to long now... H22 axle question
what axle are you guys using for the swap? accord? prelude? cl? I'd just want to know what's best. I'm sure the prelude axle doesn't match up, but just in case. thanks in advance
justin
justin
2.2 auto and coping
i hope it is....i got a friend that has a h23 layin around and ....get this....he wants to swap mine for his....
h23
5spd
ecu
+front axels i think...
just need to know what i need to get to swap....auto to man.
pedals..etc
oh and i got a mechanic that will do it for 300...
h23
5spd
ecu
pedals..etc
One custom CL
Swap is simple. ECU hook up might be a lil of a prob depending on the set up but over all its fairly easy. Driver's side mount (prelude) needs to be shaved a bit and welding required by downpipe.
Trailblazer = SUCK
Man fuck all that. use the stock cl axle for the passenger side and get the half shaft and drivers side axle from a 94-97 accord. The half shaft bolts right to the block and the splines match up with the prelude tranny. no welding cutting or anything like that. PLus.....the prelude axles are slightly longer than the accords/cl so over time they will wear out quicker and bo more prone to bind in a turn.
Trailblazer = SUCK
oh and don't get too excited about using prelude axles. they aren't much different than the accord ones. Hell you cant even tell the difference between them visibly except the reverse spline pattern.
justin7779
12-25-2015 10:33 PM
darksky
09-05-2015 03:11 AM
