Engine light...manifold question
Subscribe
Feb 22, 2007 | 10:40 AM
Hi Guys,
THE CAR IS A 98 2.3CL
Here is my problem. Some time back I got the engine light on. I hooked up the OBD scanner and the codes come out as P0170 Trim malfunction bank1 and P0171 System too lean bank1. I had posted in another thread and got some very good advice. I figured that the O2 sensor might be tosted so have decided to buy a new O2 sensor.
I did a fresh oil change and threw in some SEA FOAM in the intake tube that connects the air filter to the Carb/injector aseembly. Well the car smoked for some time and then came back to a normal idle. I noticed that there was some amount of white smoke rising in the engine compartment(I mean when you raise the hood and look at the engine). I see some white smoke very little but it is there.
Now I am thinking that the manifold might be leaking...IS THAT SO??? If it is do I have to change the manifold or just the gasket?? If I have to change the manifold how do I remove the bolts they appear to be rusted. I have already broken on on the sheild and am scared to touch any other bolts. When I reach the bolts that connect the Manifold to the engine will they be rusted as well and difficult to loosen or there are chances of them breaking as well?? I would like to know if some one out there had faced similar problem and what is a safe way to loosen these bolts?
ALSO IS THIS LEAK CAUSING THE CHCEK ENGINE LIGHT ON AND THE CODES P0170 AND P0171? I AM JUST WOUNDERING THAT THE MANIFOLD GASKET MIGHT BE WORN AND NOT THE O2 SENSOR AND THAT IS WHY THE COMPUTER IS THROWING THESE CODES? AM I CORRECT HERE ? CAN SOME ONE ADVICE PLEASE BEFORE I GO SPENDING MONEY FOR STUFF THAT IS NOT REQUIRED?
THE ONLY MOD THAT I HAVE IS THE OBX MUFFELERS THAT'S IT. IS THIS MOD EFFECTING THE O2 SENSOR READING? I GUESS NOT AS THE MUFFELER IS WAY AT THE END OF ThE ENTIRE EXHAUST SYSTEM.
PLEASE ADVISE.
THANKX
JAVED
Reply 0
Feb 22, 2007 | 10:58 AM
i believe your supposed to throw in some sea foam. then do an oil change.
it might just be the sea foam smoking, its supposed to do that.
Reply 0
Feb 22, 2007 | 12:43 PM
Quote: i believe your supposed to throw in some sea foam. then do an oil change.
It'll keep burning carbon until you drain it and all the crud out of it
Reply 0
Subscribe
