engine failure
Old May 22, 2004 | 01:13 PM
namesake's Avatar
engine failure
this is my first time posting, so pardon my ignorance in advance, but i am a 1st gen CL owner who has been having serious engine problems lately.
my engine just cuts off sometimes as i am slowing down, making turns, and occasionally when i am just starting out. i just had the ignition switch replaced, but am still having these problems.
does anyone have a clue what might be the problem?
btw, can someone tell me the exact function of the EGR valve?
Old May 22, 2004 | 10:18 PM
wilp99's Avatar
egr valve recirculates exhaust gases back in to the intake so it can be burned off all the way. usually will cause light to come on and gas milage to go down.
it sounds like u got eather a TPS (throttle position sensor), or like i had a problem with was the IAC (idle air control valve) if there is no check engine light besides when it dies, i would change the fuel filter first. as that is the cheapest thing to do. and a car can always use a new one. both of the above valves can be changed by urself. unless ur really not mechanically inclined at all. is there a check engine light on when it is running? if it is any of the sensors i would think its the TPS sensor. get back at me.
Old May 23, 2004 | 12:31 AM
Cocoa's Avatar
2600lb CL
damn...my check engine light came on tonight....how much for the EGR valve?
Old May 23, 2004 | 01:24 AM
Chinisimo's Avatar
does it idle really low almost to a point it shuts off? you might have a vacuum hole leak somewhere or maybe a crack in your air intake hose.
Old May 23, 2004 | 10:03 AM
wilp99's Avatar
cocoa- what kind of cl do u got? year, and milage. cause there is a warranty extension on egr valves with cars under 100k mi. its free to get replaced.
Old May 23, 2004 | 10:10 AM
Chinisimo's Avatar
cocoa, if you'r out of warranty and need to buy the egr valve, i still have mine, it's never been opened.
if you have a 3.0
Old May 23, 2004 | 10:19 AM
namesake's Avatar
thank u so much for your input. i wish i would have looked for this site sooner.
wilp: the light stays on. i just had the both the fuel pump and fuel filter replaced not more than a month ago. that was the last time, as chinisimo suggested, it idled really low.
another funny thing that i am noticing, it seems to be more likely to cut off during the day than at night. especially the first time each day i leave the house for a drive.
i'm not that mechanically inclined, but i sure will be to save myself from dumping more $$$ to these mechanics.
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
