engine code...need help!
Old May 5, 2005 | 06:53 PM
endlessdragon's Avatar
~ The Endless One ~
Ok so my engine light came on and i did the paperclip trick...i got 8 blinks from the engine light. SRS light also blinked once (to my knowledge it shouldn't?).
the 8 blinks were all the same so i'm not sure if they were "long" or "short" but they were about a second in between.
so i'm guessing this is either a code 8 (Top Dead Center Sensor Malfunction) or 80 (Exhaust Gas Recirculation Insufficient Flow)?
any ideas?
Old May 5, 2005 | 07:04 PM
~ The Endless One ~
btw...when would you start counting the blinks? is it when you turn the ignition on, and all the lights come on including the engine light? it then goes off and then starts blinking. do you count it from when the initial engine light goes off or does that count as one?
holy crap does that make sense?
Old May 5, 2005 | 07:12 PM
~ The Endless One ~
ok i think i figured its the EGR...
Old May 5, 2005 | 08:27 PM
wilp99's Avatar
reset the ecu by disconnecting the positive on the battery for 30 min.. if u have a capacitor, make sure you turn on the headlights for a few minutes to drain it. or ull never reset the ecu.
Old May 5, 2005 | 08:28 PM
wilp99's Avatar
reset the ecu by disconnecting the positive on the battery for 30 min.. if u have a capacitor, make sure you turn on the headlights for a few minutes to drain it. or ull never reset the ecu. anyways if u reset it it shouldnt come back for a week or two. itll give u time to get it fixed. but on the other hand if ur covered under the extended warranty plan take it to acura and have them fix it for free. i think its 97's 100k miles and 98-99's are 80k miles.
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
