Energy Suspension Hyperflex complete bushing kit
AWD Torque Monster
anybody else got a set? figured while i drop my car might as well upgrade my bushings to polyurethane. cost $84. just wonderin how install went seems pretty cut and dry. also wanted to know how much they help with body roll and control.
What can I get ya?
Do you know if they make them for a 3.0? Aftermarket kits are suppose to be really beneficial- good luck with the install its suppose to be time consuming
AWD Torque Monster
nah as long as i grease them good i should be fine. none of u have them i take it. just like a bypass valve every says ull suck up water if u get a cai. we will see. not like i cant change em back. i got plenty of time
Still trolling
Um, I had all polys in the front of mine when I did the springs. They were not from a kit, but rather individually purchased. I had the pivots(upper control arm), sways, and lower control arm done, and very well greased, twice. It squeaked...
When I yanked those POS springs, the polys came out too since I had everything apart anyway. Every speed bum p, or roll in the road yeilded squeaking. Lubbing it did help, but it came back quick.
AWD Torque Monster
finally some who has some
i did some more research and i have found mixed reviews on them. so i havent decided what im going to do yet. it appears that lower arm bushings need to be pressed out. i might just change the easy ones. ill keep you updated
1fatcrxnem1
22
06-01-2018 01:23 AM
