Emissions Failure
A-CL Post Whore w/N2O
Emissions Failure
I took my wife's '93 Accord (2.2 Auto) in for emissions inspection and it failed! ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
It passed on the Hydrocarbons test, the Carbon Monoxide test, and Carbon Dioxide test (well, there's no real test--they just give you the number).
It failed on the Nitrogen Test. Any idea what could be causing the high readings?![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
The State Standard is 2.3000 GPM. Her car registered 3.4560 GPM.
BTW: I had a new exhaust system put on before the test (axle-back and new flex pipe [between the exhaust manifold and cat] ) due to rust.
Thanks!
Thanks!
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
Originally posted by 97Acura3.0CL
slip the guy 50 bucks and it will be under the required 2.30000 gpm's
cmng 2 a lawschool near u
Did you check the catalytic converter? My brothers older accord had a similair problem, and that fixed it pretty quickly. Also does it have any aftermarket parts like your car? I know it is your wife's car, but you never know.
My Home Planet
I'm not 100% sure but I don't think it has much to do with the cat or exhaust piping.
You may want to check the EGR valve. Also make sure that there is a sufficient amount of vacuum in all the hoses and such.
Basically it means that there's too much nitrogen going into your exhaust system. If that makes any sense.
It's every 2 years!
There's no mods on this car.
My first thought was the EGR valve.
But, could be as simple as a tune up? New plugs, wires, distrubutor cap, rotor, and a can of dry gas????
1 Dog, 2 Cats and a G-Pig
I would recommend moving to a state that does not require that... my 93 accord is a POS, and I can guarentee it would fail every conceivable emmisions test... I think those cars are OBDI right?
Scooby Guru
Yeah, either you're not getting enough spark (distributor, plugs, plug wires, etc) or your cat is dying.
I passed the NJ sniff test even after I removed 2 of the cats on my WRX. Just gotta make sure that the car is completely warmed up and running properly.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
