EGR port cleaning 2.2cl
Alright, so I'm throwing the P0401 code (EGR insufficient flow) and I found a write up for the F22:
http://www.dhost.info/accordinfo/howto/egr.html
However, its not very detailed.
When I clean the built-up carbon from the EGR ports on the intake manifold, am I supposed to let all the carbon just fall into the intake manifold and get sucked up when I turn the car on? Will this hurt it?
I know this has been discussed many times. my car is under 150,000 miles.. Im gonna take it to the dealership for the egr recall but ive got a CAI do you think i should switch back to the factory intake before i take it up there?
I finally cleaned out my EGR port yesterday. All 4 holes going into the intake manifold were 100% clogged with carbon. it took about 2 hours of scraping and soaking in carb cleaner but it was well worth it. The car idles smoother and is much smoother throughout the entire power band. Idles lower at startup and takes less time to warm up. Its too early to be conclusive, but gas mileage seems to have been restored. Best mod yet and really not very hard using the instructions in the link i posted above.
i just took out my manifold and cleaned it out but i have a question. Do I have to change the gasket (the green thing)? a friend told me id have to change it no matter what, and i hosed down my manifold so now its wet as well. can i just waitfor it to dry and keep it, or do i have to switch it out? how much does it cost?
InFaMouSLink
Oct 30, 2015 09:43 AM
