dumb oil question
Old 08-18-2003 | 07:07 AM
r3mix3r's Avatar
dumb oil question
how high should the oil go on the dipstick? past the 2 holes?
Old 08-18-2003 | 07:31 AM
uiskibum's Avatar
its paid for
it should just be even with the 2nd hole...i think, stress think, we use 4.5 quarts. This is including what ever you already put in the oil fliter.
Old 08-18-2003 | 10:10 AM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Right, as long as the oil is between the 2 "holes" you're ok.
However, the best situation is to have the oil even with the top "hole".
Old 08-18-2003 | 11:47 AM
TeamBlurryCL's Avatar
TEAM BLUR So. CAL
the bottom hole is the minimum you should have the oil at. the top hole is maximum or it means you engine is hot. have it somewhere in the middle because oil expands when it heats and contracts when it's cold. putting it in the middle lets your oil have space to expand and contract. if you fill it up to the second hole, your oil pan will be over filled and your car will feel slugish.
Old 08-18-2003 | 01:58 PM
That's never happened to me.
Old 08-18-2003 | 02:04 PM
wingman's Avatar
Old Man
"if you fill it up to the second hole, your oil pan will be over filled and your car will feel slugish."
I think you feel it on I-4's.
Old 08-19-2003 | 04:05 PM
r3mix3r's Avatar
I was drivign this afternoon and waited about 1hr 1/2 but it was still a little hot... and my oil was bout 2 inchs over the 2nd hole!
Old 08-19-2003 | 07:41 PM
Chinisimo's Avatar
you have way too much oil in it. i dunno what happens other then the "sluggish" issue, which i'm not sure about. our 3.0 takes 4.6 quarts. so i just put 5 quarts in it. i don't think that would be a problem...
Old 08-20-2003 | 10:42 AM
nandowong's Avatar
Work safe avatar bish :D
2 inches over the second hole? does not seem possible unless you have like 8-10 quarts in there. cuz it takes 5 just to get it to the second hole, (about an inch up the dip stick) who did your last oil change?
Old 08-20-2003 | 10:49 AM
ib_jimmy's Avatar
what brand and weight of oil do ya use for ur 3.0?
Old 08-20-2003 | 11:00 AM
BEETROOT's Avatar
Yeehaw
did you wipe the dipstick off and then put it back in to test? if you just pulled it straight out and looked at it the oil could be two inches over the dot...
Old 08-21-2003 | 01:20 PM
r3mix3r's Avatar
checked it this morning and it was like 1/2 inch over... i guess thats ok
bungln
02-20-2019 08:47 PM
IIDXholic
10-08-2015 07:53 AM
wusty23jd
09-24-2015 11:41 AM
atsx1313
09-22-2015 09:04 PM
datadr
09-12-2015 09:12 PM
Quick Reply: dumb oil question
