Door Lights
Old Feb 27, 2005 | 09:24 PM
MikeSwing's Avatar
Door Lights
What size are the door lights on our first gen? Does PIAA make any that fit and are bright white? If so, where's the best place to buy them? Thanks fellas.
Old Feb 28, 2005 | 12:02 PM
viet97cl3.0's Avatar
andysautosport has them but shipping is a b**ch!! they wanted $60 for 3 bulbs shiped!!
Old Feb 28, 2005 | 01:13 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I've been wondering the same thing, anyone know the actual bulb sizes? Or should I do an LED conversion. Would like to do hyper whites though, unless the led's are my only option
Old Mar 2, 2005 | 01:12 PM
MikeSwing's Avatar
No one out there has anymore input on this? Help a brotha out.
Old Mar 2, 2005 | 02:34 PM
hybridnrg's Avatar
...is now Carbon Fiber'd
check this site out....might be getting some for the doors from here
http://superbrightleds.com/1157.htm
Old Mar 2, 2005 | 03:22 PM
(Mid-Atlantic)
Those look pretty sweet, is that our size? the 1157 ???
Old Mar 2, 2005 | 03:31 PM
uiskibum's Avatar
its paid for
1157 will NOT fit in the door. Go here and read...I suggest bookmarking it for future reference.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Old Mar 2, 2005 | 03:38 PM
hybridnrg's Avatar
yeah but they dont list the door lights. on the website they call it Festoon Base Bulbs look near the bottom. something like this
Old Mar 2, 2005 | 03:41 PM
klepto's Avatar
i have polarG m16's in my doors
Old Mar 2, 2005 | 09:09 PM
xxx's Avatar
xxx
I made my door and interior bulbs.
use one 100 ohm resistor for 3 leds for a 12V application.
third pic shitty I had no tripod.
You could do them in any color white, red, blue ect.....
Old Mar 3, 2005 | 02:43 AM
legendaryCL98's Avatar
'07 November = STI
xxx! u need to bring some of those LED's down to seattle! i dont know how to make it in a row like that.. i really sux at technical stuff
Old Mar 3, 2005 | 11:23 PM
(Mid-Atlantic)
XXX, that's sexy as hell. The whole interior of my car is green, except for the door lights, that's EXACTLY what I want to do for my cars. Lookin sweet man, what type of led's are those?
Old Mar 3, 2005 | 11:55 PM
ajtcl's Avatar
Peace, Love & Acura
RADIO SHACK , hell yeah a techie.. woah
Old Mar 4, 2005 | 10:18 AM
xxx's Avatar
xxx
The lights you should buy are not the green colored LEDs but, you should buy the clear LEDs that light up green. The clear cased LEDs that light up green are the brightest ones you can get, they're 1000X brighter than an ordinary bulb and they dont get hot.
The green ones in this picture are not the ones in my car. This picture is my experimental set. The ones in my car have a clear outer shell.
Before you solder the LEDs together you should shave the tips off the LED bulbs. This will widen the beam of light. Make sure you dont shave to far down the bulb.
Old Mar 4, 2005 | 10:30 AM
(Mid-Atlantic)
Where did you pickup the clear (green) leds? Radio shack or somewhere similar?
Old Mar 4, 2005 | 10:37 AM
xxx's Avatar
xxx
Radio shack was too expensive. I bought them at an industrial supply store that sells electronic stuff. You buy in bulk they will knock off a percentage off the actual price. I think I bought 20 LEDs @ $1.75 ea. The price for one LED is 2.75 ea CDN.
The ones that have the green exterior shell was approx $0.80 ea. but not as bright.
Old Mar 4, 2005 | 03:28 PM
uiskibum's Avatar
its paid for
If I'm not mistaken the door light is this.. Step/Courtesy light DE3021
Ebay is an ok place to get mass quantites of LEDs. I got some white and blue 3mm leds that are still burning after almost a year (I know they have a high lifespan, but sometime you get crap and they burn out fast).
Old Mar 4, 2005 | 04:03 PM
(Mid-Atlantic)
What did you use your led's for?
Old Mar 4, 2005 | 06:38 PM
xxx's Avatar
xxx
I replaced all the interior lighting: dome, door, map, trunk lights ect....
You can use them, for anything as long as you have the right resistor inline. A general rule is:
for every one led use 300 ohm resistor
for 2 leds use 200 ohm resistor
for 3 leds use 100 ohm resistor
for more than 3 leds in a row you have to have a 100 ohm resistor in between the set of three.
For example: POWER_100 ohm_led_led_led_100 ohm_led_led_led_100 ohm_led_led_led_and so on......
So you can actually replace anything in your car. I wanted to do my taillights but i was too lazy.
Old Mar 4, 2005 | 07:14 PM
BlueCLRycR's Avatar
eh f**k altezzas.
damn i wish i could solder. id get bright whites for the inside and put bright blues for headlight and turn signal accents. BTW what did you use to hold them together, hotglue or something.
Old Mar 4, 2005 | 07:42 PM
xxx's Avatar
xxx
I bought a blank curcuit board and cut it to the size I needed.
I soldered the peices in and used hot glue to protect the back of the curcuit so I dont ground it out on anything.
The hot glue it just to seal the backing. Everything else is soldered.
Old Mar 4, 2005 | 09:01 PM
BlueCLRycR's Avatar
eh f**k altezzas.
i need to learn how to solder bc that shit is awesome dude. props on major originality. about how much did it cost for all the materials and how much of those LEDs and resistors do i need to buy.
Old Mar 4, 2005 | 09:23 PM
xxx's Avatar
xxx
soldering gun and solder = $10
glue gun w/ glue sticks = $10
leds 20 pk = $40
resistors 100 pk = $ 5
blank circuit board = $ 3
14 guage auto wire = $ 5
soldering is easy :
- just hold the two things you need to solder together
- put the iron on the area you want to join
- touch the iron with the solder
- wait 2 sec for solder to cool down.
Old Mar 5, 2005 | 10:34 AM
uiskibum's Avatar
its paid for
I was working on redoing all my dash lights with white leds, I got to the fog light swtich, the sunroof swtich, the cruise button, and the ligth in the ashtrya, and around the cig. lighter. Then I just kinda ran outta time.
What resistor you need really depends on the spces. of the leds you are using. If it is a bright led then you will need to have a higher resistor to get it to a lower output level (if that is what you are going for). If the resistor is to low then it will be abrighter but it will burn out faster.
Here is a really good site that explains how all this works:
http://www.theledlight.com/ledcircuits.html
it has a link to a great resistor calculator as well.
Soldering is also really easy, you just need to be patient and careful not to fry the led. There are lots of tutorials out there, just google for it. And the only advice I have if you are going to play with all this, get a multi-meter.
Old Mar 5, 2005 | 02:00 PM
DaInFaMMuS1's Avatar
hey how can u replace the rear license plate lights?...i hate the fact that theyre yellow and and all the lights in the front are white/blue
Old Mar 5, 2005 | 03:37 PM
ajbent86's Avatar
how did u get the lights under the dash?? thats a nice touch, im assuming it comes on with the dome light..........some DIY info on that would be awsome!
Old Mar 5, 2005 | 05:58 PM
(Mid-Atlantic)
You can buy new light bulbs for the license plate holder, I got my set from VXCL, can't wait to put em in. I'm plannin on soldering a bunch of LED's, I will try to throw together a quick DIY when I get to it, with some pics. Thanks for the help xxx
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
aleo12
4G TL Problems & Fixes
Sep 17, 2015 03:48 PM
ahsm
Sep 9, 2015 08:35 AM
drewdeezy03
Sep 3, 2015 08:04 PM
