Disabling second 02 sensor
Old Sep 21, 2006 | 04:44 PM
Fushuman's Avatar
Question Disabling second 02 sensor
Well seem like I need to replace my Cat.
Check engine, P0420 "Cat below threshold", checked cat and its rattling inside.
I did a search put couldn't find much. If i disable (re-wire) the 02 sensor after cat it won't affect the ECU at all!? Could I pass smog in NY with this trick and yet not kill my engine in the long-term (140k miles and i wanna double it)!?
And as far as performance is it better a hi-flow or a generic cat. I heard that OEM cats are designed to give a better exhaust flow at highway speeds that actual hi-flow aftermarket cats. And OEM give better gas mileage than hi-flow. Is this true?
Please correct me if im wrong and suggestions on this issue, since my inspection is in a week
Thanx
Old Sep 21, 2006 | 08:14 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Search for o2 bypass, the bypass has been posted on here several times
Old Sep 22, 2006 | 07:52 AM
Fushuman's Avatar
thanx man i'll search thru it,
but what about comparing hi-flow vs. generic cat in performance and life-time
which is better
Old Sep 22, 2006 | 08:12 AM
(Mid-Atlantic)
That's pretty straight forward. Hi flow is better performance wise.
Generic is probably better as far as lifetime if it's comparable to oem or original equipment.
Old Sep 22, 2006 | 10:29 AM
Fushuman's Avatar
Ok, and do hi-flow cats come with the ceramic honeycomb or are they just a straight pipe.
sorry for all these q's, i just wanna get a clearer picture of this.
Old Sep 22, 2006 | 10:30 AM
Fushuman's Avatar
and don't wanna get ripped of @ Ebay
Old Sep 26, 2006 | 10:24 PM
Fushuman's Avatar
Well I've searched for Catco hi-flow cat and I saw 2 types:
bolt-on fit for $140 and weld-on for $80
are these the same thing or one is hi-flow and the other isn't
sorry to drag this thread but can't find specific info on the search and need some help soon
RobbDizzle
Oct 15, 2015 11:16 AM
joflewbyu2
Oct 8, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
