D4 doesnt light up in odometer
'97 CL 3.0 Black
my D4 light stopped lighting up in the odometer all of a sudden today.......what happened? is it a easy fix?
thanx in advance
thanx in advance
im back biaaatch!
hey man that sux
its an easy fix thou
there are two screw on the top of the black ring around the guages. Take those out, then use a thin knife to pop out the cruise and dimmer switches, and theres a scre behind then. after that, lower your steering collumn all the way and pull it out. There are then like 4 screws honding the guages in, two on top, two on bottom. pull those out and slowly tilt it down, then remove the two upper frame pieces. after that, discvonnect the plugs and jakn it out. then take the clear plastic piece off and remove the inner bezel, and low and behold, you will see the lights. i believe you have to pull the back piece off, and then reassemble in reverse order! its as easy as 123. I am such an expert on these guages after my indiglo install. lol
Good luck
Brian
Good luck
Brian
AWD Torque Monster
wait just D4? on my car there was only one bulb behind there and when i installed indiglos i left them all out to discover i am an idiot and had to put in the one bulb to show what gear i was in.
'97 CL 3.0 Black
^^^^ yeah...just D4 doesnt light up......
anyway, thanx for the replies ppl, i guess its a easy fix after all....but what bulbs are they?
also, what bulbs are the lights illuminating the entire odometer? one of them blew also....
thanx again...
thanx again...
yes definately do dis yourself...i just put on my indglos yesterday and it wasn't THAT much of a hassle.
Go to that one acurafactory part place...sorry i forgot the link but they tell you all the part #'z and stuff on dat site...u can also just buy the bulb directly off them
im back biaaatch!
the bulbs that light up the odometer are 194s like you put in your corner lights. you can add some red ones like i did, makes it look sweeeeet.
Brian
Brian
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
