CV Boot/Axle Replacement
Old Sep 27, 2007 | 01:51 PM
unlewser's Avatar
My drivers side cv boot is torn, so i was going to replace the whole axle.
I dont have to remove the intermediate shaft and have transmission fluid leak all over do i?
94-97 4cyl accord axles should work right?
any tips from DIYers
Old Sep 27, 2007 | 01:57 PM
gotguinness?'s Avatar
I believe this is what you're looking for as far as a DIY:
https://acurazine.com/forums/showthr...highlight=axle
Old Oct 28, 2007 | 02:00 AM
unlewser's Avatar
i replaced my driverside axle and now i have clicking when turning right......
before my outter boot was torn with no clicking, now with replacement axle, good boots and clicking.
Is there anything i could have done wrong when installing it, or is it a bad remanufactured axle?
i thought it was as easy as detach the old one from the hub and half shaft, then re insert it in the half shaft and hub. am i missing something?
Old Oct 29, 2007 | 03:33 PM
BC2003UGA's Avatar
5th Gear
could either be a bad axle or you put the left side axle on the right side
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
niray9
Dec 8, 2015 07:34 PM
Billu99tl
Sep 13, 2015 11:30 AM
