is this crap????
Old Nov 19, 2002 | 06:55 PM
clac225's Avatar
tlac356
is this crap????
[URL=http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1872671152]
Old Nov 19, 2002 | 07:00 PM
moforose3.0's Avatar
What can I get ya?
what is it?
Old Nov 19, 2002 | 07:22 PM
athlonxp's Avatar
Re: is this crap????
Not necessarily, but bullshit is lurking. This so-called mod advances the timing of detonation of the engine and may cause your engine to ping, knock, etc. It will give you a small increase in HP but not worth the risk. The resistor is usually held down by Electric tape (unless one plans to solder) and can easily short out.
Pinging and Knocking otherwise known as Pre-Detonation occurs when unburned leftover fuel vapors get superheated and causes the engine to go off at the wrong time. The intake sensor mod will make you run rich and causes this build up that will lead to pinging. Eventually if the problem is not corrected the engine will overheat to a point where metal becomes liquid and that's when you say goodbye CL!
The mod also depends on the rating of the resistor. But undoubtingly the seller did not test this on our vehicles and would not know. A high rated resistor may lead to the pinging and predetonation and to avoid complaints the seller must be selling a low rated resistor which would not give an increase at all in HP.
So to say in short, don't be fooled by that jackass. A resistor costs $.99 and a strip of electric tape is less than $.02 why pay $4.99 plus shipping? or anything over a buck? One thing the seller may get credit for is knowing which wire of the ECU to splice into.
Well, hope this helps,
James
clac225's Avatar
tlac356
a chip
Old Nov 19, 2002 | 07:26 PM
clac225's Avatar
tlac356
that was a very thorough and in depth reply....thank you
Old Nov 19, 2002 | 07:30 PM
athlonxp's Avatar
No problem, just helping a fellow member. I was almost fooled so did some research.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
visiter555
Apr 9, 2016 12:56 PM
Skirmich
Oct 1, 2015 12:59 PM
CaliBud916
Sep 19, 2015 01:56 PM
HOWELLiNC
Sep 5, 2015 03:09 AM
