Crank pulley removal?
Old Jul 24, 2002 | 03:15 PM
q2slinger's Avatar
Has any removed the crank pulley on a 3.0? I've been tryin to install a UR crank pulley but can't remove the stock piece. I've tried two different air guns and a three foot pry bar.
Does anybody know if the crank pulley bolt is reverse threaded?
Old Jul 24, 2002 | 03:18 PM
jttoombs's Avatar
The Human Radar Detector
You can borrow or buy a pulley remover from advance auto parts if you have one
Old Jul 24, 2002 | 03:46 PM
97CL2.2's Avatar
Man i'll tell ya... I had that same problem- i even went out and bought that stupid tool... Wound up breaking the drive...
I eventually went over to my mechanic friend and threw it up on the lift... He held the fly wheel with a screw driver while i used the handle from a jack (about 4 feet long to break it loose)... Should have seen that handle bend ... I thought something was gonna break. So i put my underdrive pulley in and found that i had the wrong belts... 10pm... had to put everything back in and put the bolt on "not so tight"...
Went to take it off again... NOPE!... Had to go to a friend's dad's machine shop who used every gun he had before he was finally able to break it w/ his Strongest... To end this story, i put it back on w/ his weakest gun, drove it home and was able to pull it off...
PAIN IN THE ASS! I would wait til it's time to do the timing belt- that's what i did.
G
Old Jul 24, 2002 | 03:50 PM
97CL2.2's Avatar
Re: Crank pulley removal?
Sorry... I remember thinking the same thing but forget what the answer was-
Old Jul 24, 2002 | 04:52 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
It is NOT reverse threaded.
I had to take my junk motor to the dealer to get it off. Their impact didnt work either.
They had to use 2 five ft breaker bars and their special tool.
Go to a honda dealer and offer em $20 to break it loose and then slightly tighten for the drive home (its keyed so youll be fine).
I tried torching, torqueing, etc. They got it off in 10 min with their tool.
Old Jul 24, 2002 | 06:18 PM
q2slinger's Avatar
Thanks guys. That helps alot. Now I don't feel so bad.
I don't know why that nut is torqued so high? The pulley is keyed so i wouldn't think it would need to be so tight (181 ft-lbs).
acuratl26
Apr 23, 2020 07:30 PM
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
