Corner bolts?
Old Oct 20, 2008 | 10:38 AM
bigT's Avatar
Corner bolts?
Hey guys, got my clear corners and realized that I dont have the mounting bolts for them. Stupid question I know, and I have searched but not found anything helpful, does anyone know what the size/type of bolt I am looking for is? Even a picture would be better than nothing, I Just hate to go to the sdealer for something I could get at the hardware store. Thanks in advance.
Old Oct 20, 2008 | 11:11 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Do u have the screws from your stock amber corners? You're supposed to just swap them, I bought a new set from www.acuraautomotiveparts.org they're just screws though
Old Oct 20, 2008 | 01:08 PM
bigT's Avatar
I would have but there were no corners on it when I bought it. I thought it looked like there was some special head on it at least.
Old Oct 20, 2008 | 01:11 PM
starboy2nv's Avatar
First EVER K24 Turbo CL
screw and spring
Old Oct 20, 2008 | 01:21 PM
(Mid-Atlantic)
There's a little plastic cap, but u could probably ghetto rig it with just a screw
Old Oct 20, 2008 | 02:05 PM
bRunCL's Avatar
http://www.acuraautomotiveparts.org/...s=&view=normal
Here is the diagram^
You will probably need 2 qty of the following 93913-24480 Screw to hold the spring, 33302-SY8-A02 SPRING, 33303-SM4-003 HOLDER. You might need 90302-SA4-003 NUT, SPRING (4MM) but i didnt use them. Your dealer might have them in stock def worth a call
Old Oct 20, 2008 | 03:02 PM
bigT's Avatar
Thanks, that helped alot. I needed number 3 on the diagram, Acura ordered it for me, cost about 7 bucks for both.
Old Oct 20, 2008 | 05:38 PM
purple3.0haze's Avatar
i just took a three inch nail after mine broke in a collision with a bush. Just go ahead and stick it in there and it'll hold into the bar thing with the hole in it. 3 months and still holdin on strong!!
Old Oct 20, 2008 | 05:44 PM
bigT's Avatar
^^^ Whatever works, already ordered em, Hell, its seven bucks, and I know it will be right.
Old Oct 20, 2008 | 07:10 PM
(Mid-Atlantic)
Till the nail falls out under your tires
Old Oct 22, 2008 | 04:46 PM
bigT's Avatar
just an update, got the parts today and installed the clear corners. In the process figured out that both the bulb connectors for the driver side corner light are missing. Guess its back to acura again. The lights look good, and even though I have cleaned the haze on the headlights already, they make the headlights look dull again. I might polish them again, but then again I might just replace them. Might be a good oppurtunity to do some projectors...Will do some pics soon, gotta do some major washing first, I think I ran through a major swarm of gnats.
Old Oct 23, 2008 | 02:56 PM
not too worried. i have faith in my repair skills
tsx_boy
Dec 13, 2019 08:33 PM
neuronbob
23
Jul 16, 2019 10:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
Sep 25, 2015 06:05 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
