Clutch question
well not severly just a tiny little bit at the top of engagement when it is cold or when i run the AC and there is a load on the motor, other than that it is fine.
However the car has 123,000km on it and that clutch fluid is prolly original. I know on my girlfriends civic you can adjust the cluth by turning the cable. Can that be done with this car?
there is no cable its all hydraulic. u have to bleed the clutch and see wadup. if u need a new clutch i www.clutchcityonline.com is a cheap place to get one.
Originally Posted by froggystyle14
i bought the exedy stage 1 racing clutch and act light weight flywheel and the are both awesome parts
thats the exact same setup i installed on my homeboys 96 prelude si. it made 1ktimes difference...
try GM syncromesh for your trannyfluid. heard some VERY good reveiws on it. supposed to smooth things out quite a bit. do a search on it over at www.honda-tech.com
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
