Clear Corners Install
I'm sure there is instructions somewhere around here, but I've looked everywhere (yes, in the archives too).
Can anyone provide a link to the install instructions for clear corners
There is a screw on the side of the turn signals...look deep you should see it. After that they should pop out and then you unclip the two harnesses. Take the spring offa the old housings and put them onto your new ones. You need them. They just plug in the new ones...put them in and put the screw back on...simple.
ENGAGE MY VTEC BABY!!!!!!
if you want the clear bulbs use the stock ones or upgrade to something better, im my sig i should have a pic of my clear lights with piaa yellow, curtesy of Nomad
Thanx for helping the new guy out. I just tried it and it worked fine. I'll be installing the clears later on today. Thanx again.
The next thing I wanted to try is blackening out my stock grill. Is the grill pretty easy to take off?
cycdaniel
12-17-2019 10:58 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
