cl project update
I actually have two sets of ww sideskirts one from the 4dr accord and the other set from the coupe. the one pictured is from the four door. I won't be rockin the lip kit until I'm able to get it painted. I'm still not sure which sides to use, I'll have to test fit them and see which looks best. I just don't like how the 4dr ones look when you open the door. Once again thanks to everyone for your support and compliments.
not surpised. a build will take a lot of time and money, hence they're busy making the money then doing the projects. that leaves no time for posting.
hey guys I got the car tuned last night and I can say that I'm officially addicted to boost! The tuning went great. She idles smooth and pulls like a bitch. First gear is pretty much pointless and with the tranny being so short it gets up to 120 like nothing.
I have to learn how to post videos, but once I get some vids shot I definetly will.
Wow....dude i gotta give you alot of credit for taking the time and beasting the 1st Gen CL with a TURBO.
Its something i always wanted to do but didnt have the time or place to start. Be sure to give the details on the engine. That red looks like integra milano red. Looks sharp be sure to get some nice wheels along with it. Those preludes do the car no justice. 5 lug gives you alot of options on wheels.
Oh yeah are u Florida? If so we gotta talk cause i decided to keep my car and make it into a project car. Turboing it is something i want to do when i blow this old motor and put in the H22.
As for wheels right now I'm using the lude wheels because the tires were new. Rims will probably come after I get the kit painted and installed. Here's a pic of some wheels I've been thinking about.
I street tuned so I'm not exactly sure how much power its putting out. The block is stock and I'm running about 8psi.
sup guys, merry christmas and happy new year to everyone. Its been a while since any updates but I've been spending all of time working out the bugs in the car. I've since moved on from the rims I posted up, especially when I saw they come in four lug. I recently bought a set of 17 inch tsx wheels that I'm waiting for tires for. Here's a couple of issues I've been dealing with may be some one can help me off hand without doing a search. Who ever had the car prior to me installed the prelude shift plate with an accord shifter. the shifter was way off and I could'nt figure why the shifter was hitting the ebrake. I started readin about the prelude shifter swap and noticed that my base was different from the stock cl one. I compared it to the prelude shifter assembly and it was identical. So i went to junk yard and grabbed an accord base and now everything lines up. I installed the prelude shifter but did not swap out the guts in the bottom of the shifter. The gears grind slightly when changin them-could this be the problem. I also installed a short shift adapter-this helped a bit but someting stills seem off. Next problem I've been havin has been with the pass side cv axle. Ive changed it like four times. the first one I had was spittin grease everywhere. when I took it out the inner was seperated. I replaced it with a brand new(not reman) axle from a 97-01 prelude. It was vibrating alot on acceleration and when I made left turns. I took it out, and replaced it with an accord axle i had in the garage and the vibration went away. Within a week this axle to started shootin grease at the same spot. I returned the 97 lude axle for a 92-95 lude axle. I replaced the leaking cv(which also was seperated at the inner joint) with the new lude cv and I'm still geting vibration. Can any of you H22ers tell me which axles you are using in your setup, cuz this is getting really annoying. Also what kind of drill bit do you use to drill the holes for the grill on a carbon fiber hood? Are you guys using the hood shocks- whenever I use mine it pushes the hood out of alignment, almost like they are too strong for the hood. I removed them and the hood closes fine. These are just a few of my woes, but any help would be greatly appreciated. I haven't been taking any pics, but I'll try to get some of the interior up soon. thanks, lou
They are few and far between
you were doing that before you were a mod.
Great job.
