cl project update
Old Dec 29, 2008 | 07:27 PM
  #121
Dicorp's Avatar
what is your transmission code?
Old Dec 29, 2008 | 07:39 PM
  #122
Mugen678's Avatar
No more 4x4
Originally Posted by acurahb
Also what kind of drill bit do you use to drill the holes for the grill on a carbon fiber hood? Are you guys using the hood shocks- whenever I use mine it pushes the hood out of alignment, almost like they are too strong for the hood. I removed them and the hood closes fine. These are just a few of my woes, but any help would be greatly appreciated.
I used a regular metal type bit. the cf is pretty weak and drills pretty easy. everything that was on the stock hood went back onto the cf hood, except for the rubber stops on the sides by the shocks, stock were bigger than the holes on the cf. It fits pretty good, I had to align it for about a hour back on the firewall, but its like everyone has told me on here, its a day to day thing. climate changes it greatly. around the grill is funny, one side has a finger gap and the other is almost touching on mine. I had to work with the grill for a while to get it mounted. I forget what I did, I wanna say I had to lengthen the bolts to reach to the other side of the bracket. I lmao when I open the hood though, it flies up faster than shit. hope some of that helps. also be careful on the grill if its like mine, its really tight, and I cracked the cf. I believe it was blackack that had the same problem, and I'm sure we werent the only ones. thats at least one pointer there lol.
Old Dec 29, 2008 | 07:59 PM
  #123
acurahb's Avatar
i believe its m2b4
Old Dec 29, 2008 | 08:23 PM
  #124
acurahb's Avatar
here's a pic since I lowered it and one of the wheels i'll be putting on her.
I have to get new tires, the ones on them are too big and rub the spindles.
Old Dec 29, 2008 | 08:28 PM
  #125
GhettoNinja06's Avatar
Skuuuurrrrrt!
I would definitly replace the ones on the car right now. And definitly get a grill.
Old Dec 29, 2008 | 08:44 PM
  #126
acurahb's Avatar
I already have the grill they're selling on ebay just need to paint and drill holes for it.
Old Dec 29, 2008 | 11:12 PM
  #127
MoSp33d's Avatar
N00berator
good to see ur car is comin along....cnt wait till everything is done...
Old Dec 29, 2008 | 11:22 PM
  #128
DaInFaMMuS1's Avatar
For the axle issues you're having, I'm using stock CL axles on my setup and they've worked fine. did this happen before you went boost? Maybe its making too much power for your setup, or something is out of alignment. I dont know why you've been using axles out of other cars, the stock CL axles have worked properly for me, and also Shaun with the H22 EuroR setup, and he's all motor doing 13.2 at the track with no axle issues. I'd order OEM and see how they work out. If it continues to fail, i'd check out your tranny and the mounting location for the axles that you're using, and make sure they're aligning correctly and at OEM angles. Now that i think of it, my friend with an H22 CB7 has had similar issues with his axles, and it was because they mounted his motor and tranny at an angle which put too much stress on them. IDK, i hope some of these ideas help somehow.
Old Dec 29, 2008 | 11:39 PM
  #129
Ah shit. I just remembered, you have a 5 lug conversion so stock axles probably dont work.
Old Dec 30, 2008 | 01:01 AM
  #130
Dicorp's Avatar
in that case he should be using BB6 Prelude axles...
i'm still having trouble finding the chart for prelude transmission codes, that might be also related.
Old Dec 30, 2008 | 03:22 PM
  #131
732xghost's Avatar
im using BB6 axels.
Old Dec 30, 2008 | 07:37 PM
  #132
Skuuuurrrrrt!
Wait, the hole pattern on the ebay grill is different from stock??
Old Dec 30, 2008 | 07:42 PM
  #133
ZeroCL's Avatar
W WHIP.
i think he means drill holes on the CF hood?
Old Dec 30, 2008 | 07:47 PM
  #134
Skuuuurrrrrt!
Ohhhh okay. I'm considering an ebay grill..
Old Dec 30, 2008 | 08:58 PM
  #135
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Old Jan 1, 2009 | 03:08 AM
  #136
MoSp33d's Avatar
N00berator
Old Jun 6, 2009 | 04:35 PM
  #137
acurahb's Avatar
hey guys its been a while heres an update on my cl. The h22 lasted about 8k miles before a piston cracked. Not sure exactly what caused it, but I used to beat on the motor in my accord before it was swapped into the cl. I swapped in a h22 from a 2000 lude about a month ago. I didn't put the turbo kit back on until 2 days ago. Its running strong, but I still need to drop in my walbro 255. I hate the fact that you have to drop the tank. Its going a little lean in boost according to the wideband. So I'm staying out of boost til I put the pump in. I got a set of Innovative motor mounts 95a Urethane. Those mounts are stiff as hell. the front end is mad solid and motor does not move. I have some new pics that I will upload soon.
Old Jun 6, 2009 | 08:00 PM
  #138
732xghost's Avatar
thanks for the update. i forgot about this project.
Old Jun 6, 2009 | 08:27 PM
  #139
f22vtec's Avatar
wow how the hell did i miss this thread? your cl is as tough as nails my friend. looking sexy
Old Jun 6, 2009 | 08:32 PM
  #140
acurahb's Avatar
thanks bro... I haven't been on here a while, kinda got discouraged when motor went. Plus been really busy workin on my other 4 cars.
Old Jun 7, 2009 | 01:27 PM
  #141
spencer_homer's Avatar
i like acura
sick man. more pics. are you gonna black roof? keep the black trunk? or get a red one.
Old Jun 7, 2009 | 03:49 PM
  #142
acurahb's Avatar
I put the red trunk back on it. I still need to paint the wing and lip kit.
Old Jun 7, 2009 | 04:08 PM
  #143
f22vtec's Avatar
id leave the ww lip black looks sick with the cf hood
Old Jun 7, 2009 | 09:37 PM
  #144
glad to hear ur back on and have another motor in there. what did u do w/the one w/the cracked piston? i'd take it apart n fully build the bottom end.
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
tsx_boy
Dec 13, 2019 08:33 PM
agupta3224
May 23, 2017 08:30 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
thegipper
Sep 28, 2015 01:01 PM
