CL doesn't like 5th gear
Scooby Guru
At around 25% throttle in 5th the shifter starts to buzz and it pops out into neutral. It's scary and dangerous. Anybody else have this happen?
You Fawkin Kiddin Me!
thats sonds serious.. id hurry and get it looked at... cant relate or give advice to you though... i have a 3.0 ... sorry, but good luck!!! hope its nothing...
Scooby Guru
Yeah, it does sound serious & it just started yesterday on the drive down to NYC. It happens a few times an hour, which sucks.
This car's warranty runs out in a few weeks & I'm worried that it's not bad enough for a dealer to notice unless they drive it for 20 minutes on the highway.
then you should no joke tell them to take a 30 minute or however long drive!!!!! Before yor warranty is up... make sure you are with them so they do see it.... drive if you have to....
Scooby Guru
Any recommendations on good Acura dealers in the NYC area? We bought it from Valley Stream Acura but this car has never seen an Acura dealer for service.
If the car is still under warranty, you might consider getting the extended warranty while you still can. Tranny problems are expensive, might pay for itself.
Originally posted by Casper98CL:
<STRONG>
ridinlow... in WESTCHESTER.... my boys work there... him & his friends told me about the TL&CL boards.... ACURA OF WESTCHESTER... in Larchmont, NY.. they are awesome with everything... if you wanna check it out.. get intouch with me via e-mail or PM.... later</STRONG>
<STRONG>
There is a law that says if you report a problem with your car to a dealer while under warranty, and they fail to do anything about it, even after the warranty expires they are obligated to fix it if the problem contiunes or worsens.
So, definitely get it on record that you reported the problem before the warranty expires!
Scooby Guru
Hmm, I just checked at NHTSA and while there wasn't anything interesting with the CL, the Accord of the same year seems to have had a TSB issued for 5th gear problems.
Service Bulletin Number: 97080195057
Bulletin Sequence Number:
Date of Bulletin: 9708
NHTSA Item Number: SB052947
Make: HONDA
Model: ACCORD
Year: 1997
Component: POWER TRAIN:CLUTCH ASSEMBLY
Summary: FIFTH GEAR SHIFT FORK WAS NOT MANUFACTURED PROPERLY.
Make: HONDA
Model: ACCORD
Year: 1997
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
