Chips? AEM?
Chips? AEM?
Sorry.. i may be annoying and a pain in the ass to some of you guys, i post here quite a bit..... but i have two more questions for you guys, is there any chips available for a 97 2.2CL?.. if there is what kind are there and how much?
Also i wanted to know how wide the AEM intake is?.. like the long tub thing.. i dont know the name.. cause the wider the better right??
ok well i appreciate all your help guys.. i guess you can tell i dont know much! im learning.. and use guys are helping me quite a bit!
THANX
DENNIS
THANX
DENNIS
if you have a 5 speed tranny, go to hondata.com and they can get you a good chip, the aem intake is just as good as any. the only difference is if you get a cold air intake (CAI) or if you get a short intake. i prefer the short because i've sucked up water wth the CAI's before and blown up my motor (a couple times). the CAI run down into your wheel well, you get a couple more horsepower (3 or 4 maybe) but risk blowin your engine if you're driving in water. you can change your CAI to a short setup pretty easily when it rains, but it's kind of a hassle.
AWD Torque Monster
jacob how the hell do u keep blowin ur engine? wtf are ur driving through?? a lake?? either u got some really bad luck or u like blowin ur engine. i just keep out of puddles and my car is fine for over a year now. and i drive through some nasty ass east coast storms.
Hum........what next??
i like chicken
actually, the width of the pipe any bigger than aem's sizes are pretty much overkill. remember, there is a throttle plate that stops the air from going in.
also, cai's are not always better than short rams. it varies for every car. the reason is the longer you run an intake, the less pressure inside the intake pipe. and the difference in pressure gains may cancel out/increase/decrease the gains from a cooler air temperature achieved by a cai.
i know a guy that ran a friggin filter off his throttle body in a first gen eclipse. ran quick too!
Cause stock sux.
Originally posted by CL-Z
BTW....make sure you get the 'by-pass valve'....I know I will this time.
I heard that shit don't work. The engine pulls so hard the damn by pass gets sucked into the engine...aka same effect, your engine is finished.
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
Hines57
09-24-2015 01:58 PM
