Check engine light?
Check engine light?
Hey guys,
I was driving my 97 acura cl 3.0 today and all of a sudden the check engine light came on while I was driving it. I thought at first it was a low fuel light cause I was getting pretty low, but then realized it was the check engine light.
I'm not sure why it came on, so I figured maybe if I filled up with gas it might go away, so I filled up with premium gas, and drove home but it didn't shut off.
How come it came on, is there any way for me to know what caused it to come on or find out the code, I'd hate to have to bring it up to a shop to have them charge me just to plug in a scanner and do a 2 min job. Or is there any other way I can get it to go away, my car drives great, but I hope it's nothing major?
07 tl-s in
or go to autozone. prob an o2 sensor or something stupid but make sure.disconnect the batt for a few minutes and it'll reset and the cel will go off but prob come back on within days.my o2 has been shot for months just kills gas milage.but def get it checked to make sure it's nothing major.
Bagel Bomber
From the noob thread up top.
Codes for 3.0s
How do I pull my engine codes if I do not have a scanner tool?
Do one of the following:
a. Go to Autozone and have them read your codes (it's free)
or
b. See the instructions below
WARNING!!!: USE AT YOUR OWN RISK AS SHORTING THE WRONG PINS WILL RESULT IN DAMAGED ECU.
a. Find the Data Link Connector (DLC) located under the instrument panel in the driver's side. It is bolted to the kick panel and is gray in color on the 1998 models.
b. Jump terminals 8 and 13 by connecting them with a wire/cable.
...............________
...._____|________|_____
.../|1...2...3...4...5...6...7...8|\
./..|9.10.11.12.13.14.15.16.|...\
DATA LINK CONNECTOR (DLC)
c. Turn the ignition key to ON and observe the "CHECK ENGINE" light. It will flash the trouble codes. For example: 2
long flashes, pause and then 3 short flashes = 23 = P0325 = Knock sensor circuit fault (4 cyl only).
One short flash = 1. One long flash = 10. If there are no trouble codes, the light will not flash.
Flashes.....Code(s)............................... ..........Description
1...............P0131,P0132....................... .........Primary heated O2 sensor circuit low/high voltage
3...............P0107,P0108....................... .........Manifold Absolute Pressure (MAP) sensor circuit low/high voltage
4.............. P0335,P0336.................................Cranks haft position sensor
5.............. P1128,P1129.................................Map sensor circuit low/high voltage
6...............P0117,P0118....................... .........Electronic Coolant Temperature (ECT) sensor circuit low/high input
7...............P0122,P0123,P1121,P1122........... Throttle position sensor (TPS) circuit low/high input
8...............P1359,P1361,P1362................. ....CKP/TDC sensor 1
9...............P1381,P1382....................... .........CYP Sensor
10.............P0112,P0113........................ ........Intake Air Temperature (IAT) sensor circuit low/high input
12.............P1491,P1498........................ ........EGR valve
13.............P1106,P1107,P1108.................. ...Barometric pressure sensor
14.............P0505,P1519........................ .........IAC valve
17.............P0500.............................. ..............VSS fault
20.............P1297,P1298........................ .........Electric Load Detector (ELD)
21.............P1253.............................. ..............VTEC
22.............P1257,P1258,P1259.................. ....VTEC
23.............P0325.............................. ..............Knock sensor
41.............P0135,P1166,P1167.................. ....Primary heated O2 sensor
45.............P0171,P0172........................ .........System adaptive fuel too lean/rich
48.............P1162.............................. ..............Primary heated O2 sensor
58.............P1366,P1367........................ .........TDC sensor 2
61.............P0133,P1149,P1163,64,65............ Primary heated O2 sensor
63.............P0137,38,39........................ ...........Secondary heated O2 sensor
65.............P0141.............................. ...............Secondary heated O2 sensor
67.............P0420.............................. ...............Catalyst system efficiency below threshold
70.............P0715,20,25,30,40,53,58,63......... .Automatic transaxle malfunction
71.............P0300,P0301........................ ..........Random/Cylinder 1 misfire
72.............P0302.............................. ...............Cylinder 2 misfire
73.............P0303.............................. ...............Cylinder 3 misfire
74.............P0304.............................. ...............Cylinder 4 misfire
75.............P0305.............................. ...............Cylinder 5 misfire
76.............P0306.............................. ...............Cylinder 6 misfire
80.............P0401.............................. ...............EGR insufficient flow
86.............P0116.............................. ...............Electronic Coolant Temperature (ECT) sensor range/performance
90.............P1456,P1457........................ ..........EVAP control system leak
91.............P0452,P0453........................ ..........EVAP fuel tank pressure sensor low/high input
The following codes will not flash since they require a code scanner:
P1607-PCM internal circuit failure
P1705,06,38,39,53,68,73,91-Automatic transaxle failure
HOW TO CLEAR TROUBLE CODES (after you fix the problem)
a. Remove ignition key
b. Locate fuse panel on passenger's side
c. Remove fuse no. 13 10 seconds, and then place it back in.
Codes for 3.0s
or
HeloDown
09-08-2015 06:51 PM
