Changing Power Steering Pump
Old 08-16-2006 | 04:46 AM
NitiNiteZ's Avatar
The Hefty 2.2
Although I have an h22, it shouldn't matter. Anyone have any idea how to change the power steering pump? is it easy? Mine's cracked, and i purchased another one (used). I just needa put it in or pay someone, but labor costs from the honda dealer is about $200.
Help me replace my power steering pump please!!!
Thanks in advanced.
Old 08-16-2006 | 12:36 PM
starboy2nv's Avatar
First EVER K24 Turbo CL
pretty easy....
loose hose (dunno if you have to drain oil or what)
loose screw
take off belt
put back..
Old 08-18-2006 | 03:25 AM
NitiNiteZ's Avatar
The Hefty 2.2
haha... i guess i'll have to try that. thanks
Old 08-18-2006 | 09:54 AM
starboy2nv's Avatar
i believe theres 2 screws... the top one is for the tension and the bottom one is the one that holds it to the block
Old 08-18-2006 | 06:23 PM
NitiNiteZ's Avatar
The Hefty 2.2
i heard it's hard to do it yourself cause u need to bleed the air or something...
Old 08-18-2006 | 06:24 PM
NitiNiteZ's Avatar
The Hefty 2.2
pretty much it's not just plug and play.
Old 08-21-2006 | 05:28 AM
NitiNiteZ's Avatar
The Hefty 2.2
no one knows how to change their power steering pump? or anyone can direct me somewhere that would know? searched, can't find anything...
Old 09-06-2006 | 06:29 PM
Gaujo's Avatar
i second this. Mine is on the fritz and starting to whine when i turn.
Old 09-06-2006 | 07:23 PM
starboy2nv's Avatar
b4 anything check the belt tension...
Old 09-06-2006 | 08:07 PM
zhouz's Avatar
say: zouts
On all models: Drain fluid. remove power steering belt. disconnect inlet and outlet hoses at pump. remove pump retaining bolts. remove pump. to install, reverse removal procedure. adjust belt tension. fill reservoir with new fluid. check for leaks.
from mitchell
Old 09-06-2006 | 08:40 PM
732xghost's Avatar
you have an H22??? i had no idea
Old 09-06-2006 | 10:16 PM
FULLRACE's Avatar
are you kiddin me ? why does anyone pay people to do there shit for them........its all extremely basic shit.
Old 09-06-2006 | 11:53 PM
zhouz's Avatar
say: zouts
seriously. that sounds like 200 dollars of labor right there.
Old 09-07-2006 | 12:04 AM
FULLRACE's Avatar
i dont think so. Even pullin a tranny .........be damned to get 200. I do all that stuff for free ( not in shop ) or on the job.....but for my buds.....its fun for me.
Old 09-07-2006 | 09:51 AM
732xghost's Avatar
people have busy schedules and not the reasources or know how, its understandable somtimes.
Old 09-07-2006 | 10:12 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I've talked to 5-6 shops and noone would pull the tranny out for under $200 let alone take the casing off and assess a problem
TL-Rocket
04-29-2023 02:33 AM
Yikes
05-03-2021 04:29 PM
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Changing Power Steering Pump
