changing oil
changing oil
when changing oil...what kind of oil do people use?...jus wondering....i didnt change my oil and im planning on doing it myself...thats if i know what im doing...and if anyone can help me...in fact can someone explain to me how to do it and of course what type of oil...thanks
get yourself an oil catch pan.
oil filter, some oil, hydrolic jack, jack stands
car should be warm not hot.
put the car up on the jack stands.
go under the car,look for oil pan(kinda square w/ a bolt on it)
unscrew bolt( make sure catch can is under it or else you'll have major clean up)
the filter should be directly above and to the left(drivers side)
unscrew filter. (also watch for mess)
after oil drains, replace filter with new one.
return oil drain bolt.
fill with new oil.
start car let the new oil run through for a sec.
then
yup! good to go!
fill with new oil.
then
yup! good to go!
Originally Posted by gucciCLgirl
my car has 82thousand miles....i was thinking about moblie 1...but is it a good idea?
I dislike Mobil 1 very much. I got oil leaks soon after, and I believe a few others did to (don't take my word for it). But other than that, I've always used Castrol, and was very pleased with it.
Originally Posted by 97clguy
It really doesn't matter what kind of oil you use as long as you change it regularly you should be fine.
j/k
mada51589
Jan 9, 2025 04:40 PM
