CEL Code 12 & 3 Help????
Old Mar 31, 2005 | 06:33 PM
97CLgenius's Avatar
Always drivin 100+
Here is the deal, I have an h22 in my joint and for a year now it throws code 12 every now and then. Has anyone experienced this exact code. I looked it up and means "EGR Valve Low Lift/High voltage" now common sense tells me I may have a voltage issue but what exactly should test for? Should I start with the harness and see what kind of voltage its putting out? Or do I just need a new EGR off the bat? Also my car is now throwing Code 3 but I have no clue what that is, has anyone heard of code 3? I will post this on the prelude forum as well. I was thinking since the obd 1 motor is using an ob2 harness the ecu might be throwing some messed up codes, but for the most part everything is wired correctly and it just may be that i could have a wiring problem on the EGR side. Any advice would be great.
Old Mar 31, 2005 | 07:58 PM
97CLgenius's Avatar
Always drivin 100+
anyone?
Old Apr 1, 2005 | 06:00 AM
97CLgenius's Avatar
Always drivin 100+
hello?
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
hrothgar02
Sep 28, 2015 11:08 AM
