catalytic
Do you want a direct bolton cat or something u might have to have meineke weld some flanges on? I have a vibrant high flow cat on my CL that was pretty cheap and is effective, but had to have the flanges welded on. I think there's another member on here that had a Random Technology Cat and another with a Bosal Cat that were direct bolt ons but were more expensive than mine.
I remember back when DaInfammus1 was recommending the Catco cat, but seeing your location. Ill tell you this. There are alot of muffler shops that won't touch that part of the car only because supposedly only the dealer can replace it and they don't want the liability. Are you throwing a code like P0420?
I have to replace my cat too... anyone have an issue with the Bosal cat throwing codes? Found this one for $125...
http://www.partsgeek.com/catalog/199...converter.html
...is now Carbon Fiber'd
I got a Bosal Cat from the amazon website. It was a high flow cat, but you will have problems when you get a smog test. I would suggest getting the CA compliant high flow cat to save you troubles for the test.
If you plan doing anything to your exhaust and want a highflow cat, contact SMS products. They sell CarSound cat's with various diameters and with custom lengths and flanges.
http://sms-products.com/Contact.html
They don't do emissions or smog testing up here so not really concerned if it's compliant... just wondering if anyone has had issues with a Bosal cat.
www.amsperformance.com
or make on like i did out of (2) spark plug non-fowlers found in your local auto parts store in the HELP section. Good luck
mike
no problem with high flow cats, if there is a bung for the o2 sensor you are okay. i wouldn't recommend punching out a cat, since it will fowl out your sensor. it happen to mine when the filling broke up and carbon came though.
