cat back question
Old Nov 19, 2013 | 02:09 PM
jaketk729's Avatar
cat back question
hey guys thanks for checkin it out, was wondering if this system would work with my stock cl? its a 3.0 99 im going to add headers and an intake then a NOS kit, letme know if there are other items I would need to replace/install thanks for your time
http://www.andysautosport.com/honda/...f00013686.html
Old Nov 19, 2013 | 02:25 PM
Cocoa's Avatar
2600lb CL
Hello and welcome to the forums.
This particular cat back will NOT work with your V6 CL.
I recommend buying the muffler of your choice and having an exhaust shop replace your piping with 2.5" diameter piping when installing the muffler.
Old Nov 19, 2013 | 02:44 PM
jaketk729's Avatar
ok ill try that thanks, another question is should I get this nos kit? it says its uni with any car http://www.andysautosport.com/acura/...010000505.html
Old Nov 19, 2013 | 02:47 PM
^no.
Nitrous isnt for beginners, which you clearly are.
do you even know HOW to set up that nitrous kit?
it takes serious research on how and where to plumb the nozzles for great results.
and without proper watch guards in place, you could blow the engine with nitrous.
Old Nov 19, 2013 | 03:02 PM
jaketk729's Avatar
I would have a shop install it im just trying to figure out some ways to increase hp
Old Nov 19, 2013 | 03:31 PM
Cocoa's Avatar
2600lb CL
I love nitrous and used it in my CL for almost 10 yrs.
I recommend a wet kit from Zex (Zex uses a module that helps keep your engine from going kaboom), colder plugs, and use high octane only when on the bottle. i went with a 125 shot of nitrous on the 3.0 with race gas or alcohol from your local hardware store (zylene, toulene, have 114+ octane rating)
Nitrous is easier to install than a stereo system in my opinion. It only consists of 3 wires, gound, power, and tps.
A bottle warmer is highly recommended unless you don't mind refilling the tanks at the 1/2 way point due to lack of pressure in the bottle.
The 3.0 with a 125 shot will do you wonders! I had some of the most exciting races with that setup.
Old Nov 19, 2013 | 05:19 PM
jaketk729's Avatar
so would this be my best bet? http://www.prostreetonline.com/x/zex...trous-kits.asp
also does it come with everything I need?
Old Nov 20, 2013 | 07:25 AM
^be safe out there.
Im scared for you.
Old Nov 20, 2013 | 09:34 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Old Nov 25, 2013 | 06:48 PM
DaInFaMMuS1's Avatar
Your best bet is to take your list of optioned NOS kits to the shop you will have install it and see what they're recommendation is on which kit to buy. They might have you buy a kit, or just some essential parts to piece a kit together.
Old Nov 26, 2013 | 02:05 AM
DFoster0's Avatar
+1 for Zex install is pretty easy, good luck
NJALLDAY57
Oct 13, 2015 08:25 AM
IIDXholic
Oct 8, 2015 07:53 AM
ibGTV
Sep 28, 2015 03:40 AM
