car wont start??
97 2.2cL black
car wont start??
when i hold my clutch pedal down the car wont start right away. i have to hold the key in the on position for several seconds. sometimes it wont even start on the first attempt. this has been going on for a few months now but it has gotten worse. any ideas as to what might be causing this to happen? fyi, plugs and wires were replaced recently as well as the timing belt and a valve adjustment.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by asianspec
if it clicks, its your starter. if it doesnt then its your alternator.
contrarian in fashion
sounds like an alternator problem.... either that... or tha battery isnt holding its charge very well. i had a problem similar to that when i had my Mazda
Originally Posted by AznX TL
how much gas do you have in it?
97 2.2cL black
the problem is there whether i have a full tank of gas or when its empty. i think i will have the alternator tested and hopefully thats whats causing the problem. otherwise, this might turn into a costly repair. lol
97 2.2cL black
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by chuckz
the starter doesnt click, to me the starter seems to be fine. i've had experience with bad starters and this doesnt seem to have any of the problems of a failing starter.
Switch is under the dash and bears against the clutch pedal arm. I would suggest spraying the switch liberally w/ WD40 and working the clutch up/down. If that doesn't help, then a new clutch switch will need to be installed.
good luck
Starting
If it is cranking the clucth sensor is okay, It sounds like ignition,, check the ignitions wires and also check the coil wire make sure that it is not corroded. that happens alot with the F series.
saberlove
03-11-2021 09:29 AM
bearingman07936
01-07-2016 03:22 PM
