car shakes @ 70mph
Old 07-14-2005 | 01:43 PM
Fushuman's Avatar
car shakes @ 70mph
well i took my 2.3cl to my mech. and told him what's wrong. The front end shakes at over 70mph and if i lightly touch the brakes it becomes worst, It even pulls to one side.
So he check it and say it could be that the driver side caliper is a little sticky or the brake line is faulty.
Could a stick caliper cause this problem? and do i need to replace the caliper or can it be fixed? (he said it needs to be replaced = $500 total: change caliper and replace both rotors w/ labor)
thanx for any help provided
Old 07-14-2005 | 01:59 PM
shineynitelite's Avatar
NAWWWWSSSSSS
wow 350 worth of labor.. tell him to suck his own ass
Old 07-14-2005 | 02:42 PM
kspekCLS's Avatar
ImportJunkie.net [SYTFU]
your car shakes or your steering wheel shakes? maybe its your tires, they're not evenly balanced.
Old 07-14-2005 | 02:52 PM
pebe's Avatar
Warped rotors
Old 07-14-2005 | 02:53 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Or his alignment is way off, or lugs on one of your front wheels is loose.
Old 07-14-2005 | 07:15 PM
Smalls's Avatar
Insert Sarcasm Here
Originally Posted by pebecl97
Warped rotors
Old 07-14-2005 | 07:17 PM
SupraManAG's Avatar
One custom CL
Warper rotors or unbalanced tires. Dont believe everything your mechanic says. He wants more work -> more money from you. After he changes your brake lines and the problem persists he will tell you your engine is blown.
Old 07-15-2005 | 05:08 AM
hondasir's Avatar
yes SiR
tires unbalanced?. try taking it to another shop and see if they have another say bout it. sounds like he jus made up those problems? sticky caliper and brake line, thats b.s to me?
Old 07-17-2005 | 03:02 PM
Bigpimpin18's Avatar
Soon to be H22 turbo!
ok, well if u live on the west coast, try taking it to a Les Schwab, because a complete brake job is around 200. New calipers, rotors, and flushed system all the way around. But you can check ur tires, look if there is a bulge on one of them, if so u need a new tire ASAP. Check ur balance, sumtimes if u have tape weights they can come off. Check ur suspension. and check ur brakes see if there is anything wrong with them, one caliper going in before the other side.
Old 07-17-2005 | 03:31 PM
Chinisimo's Avatar
did you go over any potholes? it can also be a bent rim
Old 07-19-2005 | 12:38 AM
Zerostatic's Avatar
100% Dominicano
I had a similar problem before and in my case I needed an alignment.
Old 07-19-2005 | 05:13 PM
ajtcl's Avatar
Peace, Love & Acura
I had the bent rim, on the inside from a pot hole. Then, I knew my rotors were warped, had them changed. Then I still had the problem with brand new tires. It turned out that my driver side front rim was off ballance by .5 grams. that is a tiny amount of weight, but it made a hell of a difference. Oh, I didn't do all the other stuff trying to fix the vibration, it all needed to be done, but after all that, I had the vibration and it was the weight. The symptom was a mild gitter in the steering wheel. And yes, under breaking it was worse.
Good Luck.
Oh yeah, It was not the allignment in my case, even before getting the weight fixed, the car road straight down the road. And it still rides straight down the road, but without vibration.
peti1212
ILX
22
01-05-2022 06:14 PM
02-25-2020 10:57 AM
Legend2TL
Motorsports News
01-31-2016 10:27 AM
kuzdu
09-10-2015 09:42 PM
jordanboi
09-05-2015 02:33 AM
