car bounces
Old 06-03-2002 | 01:00 AM
STLUSMCH's Avatar
kept the beast
car bounces
i just got my car lowered and when i go over a dip the car bounces pretty good what's wrong and what can i do to fix it
Old 06-03-2002 | 01:08 AM
d98clturbo's Avatar
Old Timer
your shocks are probably shot...you mite need new shocks..i would recomend tokico blues if your budget is tight, but if you have the cash to spend get the KONI yellows (fully adjustable hight and ride) or the KYB agx are a little less and they have ride adjustability
Old 06-03-2002 | 01:15 AM
tw1112's Avatar
Yeah I agree. Your shocks are probably bad. Did you change your shocks with the springs?
Old 06-03-2002 | 01:21 AM
STLUSMCH's Avatar
kept the beast
no i didnt how much are those tokico blue shocks and oh ya i used coilovers
Old 06-03-2002 | 01:24 AM
d98clturbo's Avatar
Old Timer
the tokico blues are about $270..they are the same ones for the 94-97 accord coupe...that is the price i can get maybe a little lower.
Old 06-03-2002 | 01:26 AM
d98clturbo's Avatar
Old Timer
what kind of coilovers did you use...if you bought some cheap coilovers...that could be the problem...as far as coilovers go i would recomend ground control or maybe skunk2...i have ground control..they are they best
Old 06-03-2002 | 01:35 AM
STLUSMCH's Avatar
kept the beast
i got some arospeed coilovers off ebay
Old 06-03-2002 | 01:39 AM
d98clturbo's Avatar
Old Timer
that was a big mistake...that is why your car is boucing a lot...the spring rate on those coilovers is too low...(that spring rate is probably good for a civic but for the HEAVY CL it is not good)
Old 06-03-2002 | 02:29 AM
STLUSMCH's Avatar
kept the beast
so will those shocks fix it
Old 06-03-2002 | 02:56 AM
moforose3.0's Avatar
What can I get ya?
Maybe if you get a real stiff shock, your ride might be alright then.
Old 06-03-2002 | 10:44 AM
STLUSMCH's Avatar
kept the beast
well whats a good shock for pretty cheap kinda on a budget but i wanna take care of this asap
Old 06-03-2002 | 11:32 AM
d98clturbo's Avatar
Old Timer
the best shock you can get for under $300 would probably be the tokico blues.....for about 450 or so you can get KYB agx which are ride adjustable ( you can set the ride yourself, if you want it stiff or soft (like stock)
Old 06-03-2002 | 11:51 AM
STLUSMCH's Avatar
kept the beast
WELL U SAID U CAN PROBABLY GET THOSE TOKICO SHOX FOR A LIL CHEAPER THAN 270 WELL HOW MUCH CAN U GET THEM FOR
peti1212
ILX
22
01-05-2022 06:14 PM
foxriderar77
11-19-2020 11:17 AM
02-25-2020 10:57 AM
kuzdu
09-10-2015 09:42 PM
jordanboi
09-05-2015 02:33 AM
